Discussing Problem in the 5.0 Mustangs Forum. I just bought a coupe with a supercharger. The car runs fine under normal driving. ...
Old July 10th, 2007, 03:32 PM   #1
Problem
I just bought a coupe with a supercharger. The car runs fine under normal driving. But when you try to get in to it the car misses. I am running 8 psi. The timing is set a 10 degrees. It has 19lb injectors with a paxton fmu, no adjustable regulator, NGK plugs (didn't check the gap), stock ignition ( in the process of buy an aftermarket), and is still a speed density car (anyone have a mass air conversion?). Anyways I know I still needs to upgrade some things but what would you guys think or what do you think I should do? Thanks
Old July 10th, 2007, 03:41 PM   #2
1987 ford mustang gt
well see when shes done
The injectors are WAY! TO SMALL.
347 stroker little street car yea its slow!!
Old July 10th, 2007, 04:37 PM   #3
blowngreenmachine's Avatar
I wouldn't say they are way too small, but they are certainly at the end of they usefulness. The FMU will extend their usefulness, but as far as the missing goes...I'd say check the gap first. With 8psi, shouldn't be missing. What is the static compression? Stock 9:1? If you want an MSD 6AL, I have one that I'd let go for $100. You are most likely pegging the speed density sensor, although I will admit I am not so clear on how it works. I also have a spair stock MAF for a set of 19# injectors.
I won't say it is the injectors because I ran 9# on a stock motor without the slightest problem with nearly the same setup (i had a MAF).
All in all, I'd say check gap, if that doesn't clear it up, check your fuel system has a new filter and the pump is working correctly.
Forged rotating assembly, sportsman 302cid, 14psi, 30#/hr inj, full length exhaust, TwEECer RT, Alcohol/H2O injection, ...
Threads Similar to: Problem
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
Has your car ever had a problem? JASonic The Clubhouse 17 September 19th, 2007 05:19 PM
big problem need help 96gtponyred 96-98 12 August 22nd, 2007 01:36 AM
RIM Problem and Help trueballerisme 2005+ 70 August 21st, 2007 08:55 PM
TPS Problem? 88Horseman 5.0 Mustangs 11 November 13th, 2006 11:46 PM
