strange vibration
Old June 28th, 2006, 11:46 PM   #1
GTCollegeGuy's Avatar
GTCollegeGuy is on a distinguished road
Send a message via Yahoo to GTCollegeGuy
strange vibration
here's the history first: i have a 94 gt with 182000 miles. i have spent about 2 weeks installing long tube headers, new oil pan and oil pump, new radiator, and other little things that i found along the way that needed to be fixed. I did replace my power steering hose, the pressure line, due to it being cut by a pulley. No big deal, bought a new one and replaced it. After i checked everything several times over (after learning from the previous incident), i noticed the other day while driving it that there is a vibration, not a big one just enough to be noticed (this wasn't here before the 2 week venture to hell and back, i.e. headers). I can feel the vibration while coasting in neutral and while shifting through the gears, i can feel it in the body (when i put my hand on the floor board) and the steering wheel. could my headers be touching somewhere i'm not seeing? i'm at a loss as to what to look for, so any suggestions, comments, or questions would be great. If you need more info, just ask, i'll try my best to explain.
thanks in advance,
Gerald
Old June 29th, 2006, 12:17 AM   #2
Mustang8719 is on a distinguished road
Are the engine mounts or Trans mount weak?
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Old June 29th, 2006, 11:30 AM   #3
Screemin3o2 is on a distinguished road
Send a message via AIM to Screemin3o2
Are you feeling it at any certain RPM or MPH?
95 Mustang GT
Slow Bolt On Car
www.steelcitystangs.com
Old June 29th, 2006, 01:13 PM   #4
I'd make sure the headers or other parts of the exhaust aren't rubbing the body somewhere. Also, have you tried neutralizing the eng and trans mounts and the exhaust. Try this, loosen up the h-pipe at the long-tubes and the tailpipes at the h-pipe. also loosen the motor mount nuts and the trans mount nuts. Put the car in a fwd gear and while holding the brake, try to go fwd. do the same in reverse. do this a couple times and then tighten the loosened bolts in this order-
1) eng mounts
2) trans mount
3)h-pipe to headers
4)tailpipe to h-pipe
this should help
88 Mustang Coupe
www.rickscarcare.net
Threads Similar to: strange vibration
strange noises The Black Car V6 Mustangs 11 October 16th, 2007 08:34 PM
This is strange! Red87DropTop 5.0 Mustangs 6 September 5th, 2007 07:21 PM
Strange Development RyanHNT Parts 5 June 25th, 2007 05:21 PM
strange..!! El_Cangri The Clubhouse 16 June 24th, 2007 11:08 PM
Strange Shocks Stangzilla 5.0 Mustangs 0 October 16th, 2006 10:07 PM
