help with 2.3L to 302 conversion
hello,
I have a 1987 convertible mustang and I would like to put a 302 that I have laying around in it. Does anyone know any places that might have a list of what's needed, and what if anything from my car can be reused, like the motor mounts and transmission...etc.?? I really haven't kept up with all the changes to the mustang over the years so I guess I have to catch up. Any help will be appreciated. Thanks |
1988 lx t-top
i can help you, no to the motor mounts no to the trans if its a stick you can use the drive shaft but you'll need a stronger rear end although that one will launch you quicker until it breaks, you can use your altenater,.....................do you plan to stay efi or go carbed????
#3 | |
Just decided to go carb. since it's from an 85 and is sort of set up for carb already. any help will be appreciated. thanks
1988 lx t-top
just make a post if you run into any trouble and i'll get back to you asap
You will need 5.0 motor mounts, headers, h/x pipe, catback (you'll need hangers), and double hump crossmember for starters. You can use a T5 from a 4 cyl as long as you use a v8 bellhousing, flywheel, and clutch assembly. They arent very strong, but will work fine to hold you over. Just don't power shift it. Curtain racing classes uses the 4cyl T5 because of the low gear. Your 7.5 is also another weak point. Replace it later with an 8.8, but will work for now.
Other things you'll want to change later: Brakes Driveshaft Springs Struts/shocks Upper/Lower Control arms |
1988 lx t-top
you cant use the 4 cyl t5 unless you change the input shaft and thats not worth it
the control arms are the same as the gt and so are the shocks. the struts mount different so if you buy new struts and you tell them its a 5.0 they wont bolt up unless you upgrade the brakes to gt because the spindles are different, and the 4cyl springs are great for drag racing so you might want to hold on to those, if you get the summit full length headers for $89 you will be able to put on a simple exhuast system with very few bends and the drive shaft is the same part # and all as the gt
I just installed the summit/flow tech headers
I just installed the summit/flow tech headers:
I am surprised no one was killed by me throwing wrenches around the garage: I wasn't able to get the Summit headers, so I got the Flow tech, which is the same thing, but in stock, but more expensive The driver side is ok, but you will have to remove the steering arm, install the last pipe, and then re install the steering arm. Oh, you have to use a hack saw, yes you heard me hack saw to cut through the header flange on the driver's side in one place, and 3 places on the passenger side: I was about to box it all up, and take it back when I finally figured out how to install the passenger side: You have to take the starter off, and then install the pipe closest to the firewall, do not bolt down, then you install the starter: Then install the next pipe away from the firewall, be sure it is routed on top of the first pipe, do not install bolts, and then position the starter wire so it will not get burnt. Then you install the pipe/collector on the last port, gop ahead and bolt it loosely, and then install thew third pipe Man, this was a big pain in the ass
"Those who forget the past are condemned to repeat it" Rev. Jim Jones |
1988 lx t-top
hack saw? I used a grinder
Thanks for all the info, if you think of anything else please let me know. You all have been a great help and I can't wait to get this project started. I'll try to update as I go.
ok some details
Swapping from 4-8 carbed. 90model lx is the vehicle being used. I done this about 3 years ago on a 90 model 4cyl . But I have forgotten how I done a few things. Mainly my + and - to the coil. I thought I remembered them coming from the harness on the drivers side. Today I start removing the efi stuff and the harness from the pass side to the EEC seems to be the harness with my coil power connector. What do I need to do here. Cause I am taking that huge wiring harness from the pass side completely out minus the air bag stuff if possible. I am going to use the duraspark ignition btw. Holley electric fuel pump. So I know I need to jumper the neutral safety switch (T5 going in auto out)
1986 Mustang GT t-top time piece! |
#13 | |
93 completely Custom
1/8 mile only
1/8 mile only
One of the best links I've found yet. I've done 3 4 cylinder conversions so far and this stuff is good. It's not all inclusive, but it's good.
Changing a Fox Mustang from a Four Cylinder to a V-8 - 5.0 Mustang and Super Fords Magazine |
07 Turbo Focus
12.93 @ 105mph
Holy Old Ass Thread Resurection Batman!!!
2007 Focus - 230/215, cams/head/manifold swap done, new #s soon ...going E85! 1985 Bronco - 351W & 4WD 1986 Mustang LX - 351W build in the works! David Michael Smith, 07/25/1956 - 12/08/2011 ...R.I.P dad! I miss you dearly! |
i have almost complete fuel injection swap over if someone is interested only missing injectors
![]() 87 Notch Doing a lot with a little _____________________________ lightweight, stock motor, and 12's? |
Here is a good thread (also by fakesaleen):
Any 4 Cyl To v8 Conversion Questions? EDIT: just saw how old this thread is, but leaving link here in case anyone else finds it in a search.
Muscle car? No Import? No Lifted truck? No Lowered truck? No When you have a Ford Ranger packing a turbo 4-cylinder, all you can do is park in the back of the car show and realize that you're one-of-a-kind.
let me know
this may be an old thread but i just found very good info here
Threads Similar to: help with 2.3L to 302 conversion
| 2v to 3v conversion??? | droppedbass87 | 96-98 | 26 | September 18th, 2010 01:08 AM |
| conversion | Mustang RacR94 | 99-04 | 8 | April 2nd, 2007 11:02 PM |
| 2.3L to 5.0L conversion | stan_doe | 5.0 Mustangs | 6 | January 23rd, 2007 01:39 AM |
| 99-04 V6 To GT Conversion ?'s | ineedajob | V6 Mustangs | 7 | November 9th, 2006 04:18 PM |
| After A 5 Lug Conversion... | 347tt | 5.0 Mustangs | 7 | September 28th, 2006 03:53 PM |
