Stutter under acceleration
I recently purchased a 89' GT Convertible and it has a stutter, (not really a miss) under acceleration. It has been converted to Mass Air. I pulled the codes and it came back as a 33 which is a egr, I just want your input. The cap, wires, rotor and plugs are new. Thanks
#2 | |
Re: Stutter under acceleration
I finally found time to work on the car again!! I removed and replaced the complete upper manifold from a car that ran fine. Still having a problem with it stuttering. Where should the timing be set on the car? I have it at 10 degrees now. Any input would be greatly appreciated.
base timing of 10 deg is good....did you r&r the egr and clean it?
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
Yes I removed the egr, cleaned it and replaced it. It seems that the stutter becomes more pronounced when the car gets warm and still no check engine light. Thanks for the help
The parts stores strike again. I started digging more into my sttutering problem and found that one of my NEW spark plugs had a crack in it and was allowing the plug wire to jump arc when it was under a load. Thanks for the assistance. GOOSE
you say that like you bought a cracked one! good find!
Threads Similar to: Stutter under acceleration
| want more acceleration!!! | 93mustanggtauto | 5.0 Mustangs | 25 | October 16th, 2007 12:15 AM |
| stutter? | CBSTANG | 99-04 | 0 | July 26th, 2007 07:47 PM |
| Acceleration Stumble | Juggalo_X | V6 Mustangs | 3 | June 13th, 2007 03:30 PM |
| Vibration on acceleration.... | lwhitetrash88l | V6 Mustangs | 6 | March 31st, 2007 08:50 PM |
| Stutter At Low RPM | psychostang | 5.0 Mustangs | 3 | May 26th, 2006 08:41 PM |
