Check Engine Error Codes
Ok, so I install a new fuel pump in my car and I get a check engine light. These are the codes that I get:
KOEO: 13 - Cannot control rpm during KOER Self-Test low rpm check. 31 - EVP circuit below minimum voltage. 67 - Park/Neutral Position (PNP) switch circuit open - A/C on during Self-Test. KOER: 12 - Cannot control rpm during KOER Sell-Test high rpm check. 21 - ECT out of Self-Test range MAP/BARO out of Self-Test range. 31 - EVP circuit below minimum voltage. 91 - No HO2S switch detected (left HO2S). I also recently pulled my throttle body and IAC off to clean them. Is it possible that I did something to cause this problem by doing that? Would someone please elaborate on what these codes mean? |
You got the numbers right, but they mean different things when the engine is off or on. The KOEO codes 13- idle speed control did not respond, 67- make sure your a/c is off, and 31 points to the EGR sensor. For the KOER test do it again with the engine at normal running temp. The codes 12 has to do with the ISC idle too low, 21, 31 and 91 to me all might be caused by the engine being cold. Have you done an EGR delete? You will get codes if you have.
91 is running lean, and I meant to say 31 points to egr valve position sensor. 12 and 13 point to the IAC which I believe could cause the 91. Tengram is better at this stuff.
#4 | |
Re: Check Engine Error Codes
31 - your EGR valve position sensor is sending a voltage value lower than the closed (minimum) value. this one won't cause any performance or driveability problems but it will make your CEL stay on. to diagnose: disconnect the EGR Valve Position sensor. with the key in the "on" position (but engine off) measure the voltage between the VREF and sigRTN pins on the harness side connector using this diagram: ![]() the voltage should be about 5volts. if it is, plug the sensor back in and measure voltage between the EVP wire and the sigRTN wire. use these diagrams to ID the wires by color: http://www.veryuseful.com/mustang/te...ng_Diagram.gif http://www.veryuseful.com/mustang/te...ng_Diagram.gif voltage should be between .25volts and .67volts. if its not, replace the sensor. if it is let me know 91 - your driverside o2 sensor is reading lean. this can cause pretty severe driveability and performance problems. to diagnose this one simplly swap this o2 to the passenger side, and move the passenger side o2 to the driverside. reset codes by disconnecting the battery for about 15 minutes and then recheck codes. if the code 91 no longer shows up, but a code 41 does, than that o2 sensor is faulty and needs to be replaced. if the 91 does show back up let me know the 21 may simply be because the engine wasn't fully warmed up, if you think it was then let me know and we'll diagnose it. 67 - as "neverfastenough" said, make sure when you run the tests your A/C is turned off. also make sure the tranny was in neutral. keep us updated
Well it turns out I am an idiot and forgot to plug my EGR valve position sensor back in. Sooooooo everything is fine now. I appreciate the detailed response TENGRAM, sorry to waste your time. It did lead me to the problem though.
#6 | |
its ok still i suggest to check out that o2 sensor code
When I re-checked the codes, everything is fine, except it is still giving me the KOER 91 error code, which makes me think the O2 sensor is bad. Could this be causing my car to idle roughly especially when the engine is cold?
#8 | |
I went to switch my O2 sensors around and they both looked pretty old and crusty, so I bought a couple of new ones and put them in. I am now getting a 41 and a 91 KOER code, however, the car is idling/running better than before. Any ideas?
Anyone have any ideas?
Do you have any ideas on what may be causing the above problem TENGRAM?
make sure your o2 ground wire is attached to the back of the heads or the firewall. it is the orange wire coming out of the harness behind your intake manifold. it has a ring terminal on the end of it. let me know
#19 on this diagram
Threads Similar to: Check Engine Error Codes
| More check engine codes. | lugthug713 | 94-95 | 1 | May 30th, 2007 08:35 PM |
| Check engine codes......can anybody help | squirt | 5.0 Mustangs | 0 | April 18th, 2007 12:41 AM |
| '02 3.8l..issues..3 New error codes | whtpny | V6 Mustangs | 16 | March 9th, 2007 12:04 AM |
| 2004 v6 with lots of error codes | jmmustang | V6 Mustangs | 4 | July 19th, 2006 08:16 AM |
| Please Help! Check Engine codes? | 97Cobra | 96-98 | 2 | April 5th, 2006 07:20 PM |
