AOD to Tremec 3550 Conversion Question
We are getting ready to try to fire my 2.3 to 5.0 conversion, we just need to tie up a few odds and ends first. The donor car was an AOD, but we put a Tremec 3550 in. We didn't hook any wiring up at the trans yet, since I don't have the harness. I know it is for the neutral safety switch and backup lights. Since I have an AOD computer, the neutral safety switch will not be used, correct? Should it start and run without the backup light switch harness connected? If not, is there an easy way to jump it until I get one?
Thanks
Current Mustangs: 2004 Cobra Convertible 1993 5.0 LX Hatchback 1992 5.0 LX Convertible |
Billy Weston
it will but under the dash there is a harness that has a looped wire that needs to be plugged into the clutch before it will crank.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
Your talking about the 2 connectors that plug into the switch at the top of the clutch pedal right? If so, those are plugged in and ready to go.
Thanks
Billy Weston
yeah
Cool, I plan to be driving it by the end of the weekend. I started thinking about the backup light harness since that is the only thing I don't have yet, and wanted to make sure that wouldn't keep me from getting it going.
Thanks
Billy Weston
the backup harness from the AOD can be modified to work with it.....
I didn't realize that. I sold the AOD to my neighbor and left the harness on it. He hasn't paid me for the tranny yet, so it looks like I will have to go repo my harness tonight
Billy Weston
oh its not a pretty mod it just works until you find another harness.
i did the aod to 3550 ceoncersion in my car. the two wires on the tail shaft of the 3550 is neutral safety. on the aod harness you will see on the plug there is a wire jumped from one pin to the opther, snip it in the middle and connect the one wire from the tailshaft to one of the cut wires and the do the same with the other.
91 Gt Convertible RNH Perfomance 331 dart stroker w s-trim dart stroker with s-trim, 91 vert
Threads Similar to: AOD to Tremec 3550 Conversion Question
| Tremec 3550 | Tony_90fox | The Clubhouse | 5 | August 26th, 2007 12:11 AM |
| tremec 3550 rebuilt | Levon | 5.0 Mustangs | 1 | August 13th, 2007 03:09 AM |
| Tremec 3550 | sn-95aac | 5.0 Mustangs | 12 | August 12th, 2007 04:24 AM |
| Tremec 3550 Throwout Bearing | jtillery | 5.0 Mustangs | 3 | June 27th, 2007 09:46 PM |
| Tremec 3550 reverse switch | athomas387 | 5.0 Mustangs | 0 | September 7th, 2006 12:01 AM |
