oil press.
Old July 12th, 2007, 02:32 PM   #1
terribleonexx88's Avatar
terribleonexx88 is on a distinguished road
Send a message via AIM to terribleonexx88
oil press.
im lookin at an 89 lx 5.0 and the oil pressure isnt exactly in the middle of the guage at idle its that normal. it has a 119000 miles and from what i can tell its not beat on at all. even the factory posi still works.
85 svo. work in progress
Old July 12th, 2007, 09:23 PM   #2
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
check for a leak somewhere man..
Old July 12th, 2007, 10:35 PM   #3
Stangzilla's Avatar
Stangzilla is on a distinguished road
Re: oil press.
Well that depends on how low it is below the middle. Second I would not totally rely on the stock gauge. Some work some dont. Could also be a faulty oil pressure switch..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old July 13th, 2007, 03:36 AM   #4
Rustbelt's Avatar
Rustbelt is on a distinguished road
my old one was in the middle. the one i replaced it with is only reading at 1/3. they are not accurate at all.
Old July 13th, 2007, 12:05 PM   #5
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
oil press.
mines kinda on the lower side too, like they said it could be that the gauge is off or if its too low your bearings could be worn.
Old July 13th, 2007, 12:08 PM   #6
ThrashN's Avatar
91 LX 5.0
11.87
ThrashN is on a distinguished road
I have over 200,000 miles on my car and the oil pressure runs about 20 at idle and 40 when driving
Old July 13th, 2007, 12:17 PM   #7
woody1 is on a distinguished road
those stock gauges are useless, I would certainly not base my decision on that gauge
Old July 13th, 2007, 12:48 PM   #8
ryans88gt's Avatar
yeah, it is worth the money to buy a mechanical gauge. At least buy a new sending unit before worrying about the pressure. My stock gauge reads on the second bar above red, but the mechanical gauge reads 45 psi.
Old July 14th, 2007, 03:19 AM   #9
tording92lxnotch is on a distinguished road
Get a mechanical guage and check it out. I have 175k on mine and mine is about 26 at idle when hot and 45 when driving hot. Its a good chance its the stock guage or sender.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old July 14th, 2007, 06:20 PM   #10
i noticed that the stang (which is now mine) has both valve cover gaskets leaking could that cause lower oil pressure?
Old July 15th, 2007, 12:08 AM   #11
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Because you're continuously losing oil? Yes.
Old July 15th, 2007, 03:39 AM   #12
No. Assuming you keep enough oil in the oil pan even if its leaking out of the valve covers that will not lower your oil pressure. Once the oil reaches the top of the heads it is no longer pressurized. It is pressurized as it is forced through your bearings and the bottm of the motor. To get to the top of the head the oil comes up out of the pushrods to lube the rockers then runs back down through passages in the heads into the oil pan. So since the oil just runs back into the heads and oil pan at this point it is not pressurized, therefore if it leaks out of the valve cover instead of going back into the oil pan you will not lose pressure. The only way you would lose pressure is if so much leaks out that your oil pan starts to run dry and your oil pump can no longer pump any oil, then your pressure will drop.
Old July 15th, 2007, 10:04 PM   #13
its not low on oil so maybe its just the gauge
Threads Similar to: oil press.
R 04 PI Cam Gears Press on or Bolt On? G.T. Rags Modular Mustangs 9 October 25th, 2007 08:41 AM
and I thought it was a press to test! WAR-PARTY The Clubhouse 5 July 30th, 2007 09:11 PM
turning up fuel press. nasty92LX 5.0 Mustangs 2 June 15th, 2007 01:47 PM
LAg when I press the gas nHuman 96-98 7 December 25th, 2006 02:41 PM
