Smog pump delete belt size with supercharger???
Old July 13th, 2007, 10:10 PM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
I was wondering if anyone knows the correct belt size and routing to bypass the smog pump on a 87 fox body with a supercharger? The alternator now sits below the smog pump so its kinda throwing me off. thanks!!!
Old July 13th, 2007, 10:16 PM   #2
That is a tuff one, have you tried using a string and going to a parts store and saying, "I need one this long?" lol
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old July 13th, 2007, 10:20 PM   #3
jam77's Avatar
1987 Mustang GT
lol thats funny yeah i was just hoping someone else has encountered this before..
Old July 13th, 2007, 10:55 PM   #4
neverfastenough1's Avatar
Thats what I would do, make sure if you take your string under the idler to subtract a little, and if you put the string over the idler pulley to add a little
Old July 13th, 2007, 11:05 PM   #5
And just know how many ribs your belt has...It will be either 6PK or 7PK...6PK meaning 6 ribs and 7PK meaning 7 ribs....I work at Bando USA during the summer but me make nissan, honda and GM belts lol
[SIGPIC][/SIGPIC]
Old July 14th, 2007, 09:17 PM   #6
Bloody Wheels's Avatar
Bloody Wheels is on a distinguished road
Jam, I think you might need a smog pump delete pully for supercharged aplications. You can get one at Holcomb motorsports. My car is supercharged and I am also in the works to rip off the smog pump. I tried a shorter belt but the way you have to route it I dont think will work. Let me know how it turns out.
One shot, One kill, NO exceptions!
Old July 14th, 2007, 11:12 PM   #7
jam77's Avatar
1987 Mustang GT
Thanks! I just went to holcomb's website and saw that delete pulley, thats the way i wanted to go in the first place but i couldnt get a answer on whether or not some of those delete pullies will accept that bracket that supports the alternator that bolts directly to the smog pump in a stock config. The shorter belts dont work i wasted a bunch of time trying that route.
Old July 15th, 2007, 02:13 AM   #8
JOEYD0730's Avatar
JOEYD0730 is on a distinguished road
ASP-025030 - this is the one i have. summit sells it. it has the holes for the alt bracket and works great.
91 Gt Convertible
RNH Perfomance 331 dart stroker w s-trim
dart stroker with s-trim, 91 vert
Threads Similar to: Smog pump delete belt size with supercharger???
Smog pump delete belt size ??? jam77 5.0 Mustangs 3 July 10th, 2007 06:17 AM
belt size without smog nasty92LX 5.0 Mustangs 1 April 4th, 2007 07:34 AM
Belt (Size To Bypass Smog Pump) terribleonexx88 5.0 Mustangs 6 October 22nd, 2006 09:56 PM
Belt Size? (No Smog Pump) imported_fox_body 5.0 Mustangs 3 October 18th, 2006 04:29 AM
How To Delete Smog Pump On 95 GT the95..5-0 5.0 Mustangs 2 September 13th, 2006 01:43 AM
