1983 Mustang GT
N/A
Bad running...
I replaced my O2 sensors yesterday. It made a tremendous difference. I then proceeded to wash my car, but left the key turned on when I rolled my windows up. My battery was drained. I popped the clutch to get it cranked, and after I drove it about a mile it started running awful. It would idle fine, but when I pressed the gas, it would barely go. I got under the hood, and it seemed to backfire, and sound flooded when I pressed the gas. What's my problem?
1988 Mustang LX Turbo
either your spark is extremely low or there isnt enough gas to support the power
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
If it is the problem that you don't have great spark....
Do you have any mods on your car that would lower your voltage? Heavy electronics, underdrive pulleys, electric fan, old alternator could cause you to have lower voltage output which is a problem now that the battery is dead. |
i have this same problem but i think mine is a leak on the front glass that gets into all my wires and its cuts out and surges real bad but after it drys off its fine
89 GT
did you drive it for a little bit?... I don't know about these computers on mustangs but a lot of newer cars need to "relearn" how the car operates, sensor readings and so forth. sometimes you have to drive it around for a little bit to get it back to normal after a power loss.
Threads Similar to: Bad running...
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| 95 GT Running Very Hot | JesusOnIceSkates | 94-95 | 14 | November 13th, 2007 04:57 PM |
| RUNNING HOT!!!!!!! | BLACKNIGHT5.0 | 94-95 | 37 | September 5th, 2007 03:27 PM |
| not running right | jkovacs60 | General Tech | 2 | August 3rd, 2007 02:13 AM |
| Just Got Done Running a 89 LX 5.0 | Bigb2000GT | 99-04 | 1 | March 19th, 2007 06:57 PM |
