#1 | |
Question for darrell about engines
- Eagle 3.4 stroke cast steel crank part #103023400
- Eagle 5.4 I beam rods part #5400CB - Forged pistons - any good brand and pick your compression (10:1 or higher) - spend the money and get a custom cam. Cam Motion is a good company. - TFS CNC ported 205cc twisted wedge heads part #51400004-CO2 - For a carbureted engine use a Victor intake, for EFI use a Victor EFI or Trick Flow R series intake. I've gone 11.0s with an EFI 347 very similar to what I've listed above in a 3300lb car with a nitrous converter. I've gone 10.8s with a carbureted 347 similar to the one listed above in a 3100lb car with a nitrous converter. A couple friends of mine are running very similar ETs with full weight fox body GTs (3300 + pounds).
Thanks for the reply. I'll probably be asking a few more questions pretty soon.
No problem.
Okay, you say 347. I have the stock motor, so I guess that's a 302. I would assume I have to buy a 347?
#6 | |
#7 | |
My Stallion is Bigger!
#8 | |
So a 306 with a 3.4 stroke crank would make a 347?
#10 | |
All righty then, now all I need is $3900.
Darrell,
I wanna thank you for your good comments, that 11 sec number really opened my eyes. I already got my Eagle 347 kit, and the cheapest place to buy from is CNC Motorsports where John Pickett & Clint Anderson can sell it to you for $732 shipped anywhere in the States (it's how much I got it for) and that includes Keith Black KB246 hypereutectic flat pistons 6.5cc: http://www.cnc-motorsports.com/produ...024&CtgID=9051 Got my block bored .060 over (max limit) so it should make 352 cid, and with a TFS cam of either: Trick Flow Specialities 51402000 Advertised Durations: In / Ex = 275 / 279 Durations @ .050 Lift In / Ex = 221 / 225 Valve Lift In / Ex = .499 / .510 LSA = 112 $159 at Summit Racing or Trick Flow Specialities 51402001 Advertised Durations: In / Ex = 286 / 294 Durations @ .050 Lift In / Ex = 224 / 232 Valve Lift In / Ex = .542 / .563 LSA = 112 $164 at Summit Racing along with my World Products Windsor Sr. heads (2.02/1.60) 64cc, 1.6 Scorpion roller rockers, Edelbrock Performer 5.0 intake manifold with heat spacer, 70mm BBK TB, 30# inejctors, 1 5/8" headers & 2.5" collector... I HOPE the motor is going to make an easy 410 HP or more (my calculated compression ratio for this build up is 10:1) This is my plan, my own recipe', but I don't have the results yet.
Threads Similar to: Question for darrell about engines
| Darrell Or Anyone Else That Knows | 95StangMX | 5.0 Mustangs | 8 | November 12th, 2007 06:08 PM |
| Darrell can you or anyone else help me??? | JONJON | 5.0 Mustangs | 13 | November 9th, 2007 05:32 PM |
| question about the 4.2L engines.... | 006leenstang00 | V6 Mustangs | 39 | July 14th, 2007 12:59 PM |
| Hey Darrell | ken5_0 | 5.0 Mustangs | 7 | December 4th, 2006 12:14 AM |
