Timing Question
Old July 3rd, 2006, 06:59 PM   #1
Vamp89's Avatar
1989 Mustang GT
Vamp89 is on a distinguished road
Timing Question
My CompCam is advanced 4 degrees from them so where should my timing be set at and how far can or should I advance it.
Ported Saleen Vortech Intake
BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump
Hooker Super Comp Long-tube Headers
Fcam
Ported Motorsport J302 Heads
30# Injectors
1.6rr
80mm Mass Air
4:11 gears
Old July 4th, 2006, 12:30 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That means the cam is ground with 4 degrees advance built into it. That is referring to valve timing, not ignition timing. You will have to experiement with ignition timing to see what the engine likes.
Old July 5th, 2006, 07:57 AM   #3
88_50 is on a distinguished road
Thats exactly right, but this will not affect your base timing. Set it at 14* and go out LS1 hunting.
Threads Similar to: Timing Question
Timing Question USMC8511 5.0 Mustangs 4 June 19th, 2007 08:26 PM
Timing Question bigbadtalontsi 5.0 Mustangs 4 March 27th, 2007 12:17 PM
timing question N02coupe 5.0 Mustangs 2 March 27th, 2007 09:03 AM
Timing Question??? NYHigH 5.0 Mustangs 12 December 29th, 2006 06:03 PM
Timing Question sfarrah 96-98 7 July 12th, 2006 04:08 PM
