big time tapping
i just got done rebuilding the top end of my 94 gt. everything went pretty smoothly. on the advice from a friend, i filled up with 89 octane instead of 93(which i've been running for years). now i dont know if this is a coincident or not but now i hear a loud rapping noise from under my left valve cover....i know the type of gas wont affect my lifters,but if anyone has any ideas, i would like to hear them....thx
You sure its coming from under your valve cover? Check to make sure your Header gasket isnt leaking. I had that problem when I did mine and thought oh man what have I done! lol Check that first!
Mark |
1999 Ford Mustang V6
when you say top end rebuild what all was done?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
RLY SRS
Have you tried putting 93 back in the car? If so did it go away?
It would be alot easier if there was a sound clip... |
i put a new lower intake, upper intake, of course all new gaskets, 1/2 inch plenum spacer, new fuel rails, new injectors. i will check for loose header bolts and hope thats what it is.
the header gaskets are copper but i guess there still not immune to leaking
Copper gaskets can leak if not properly tightened. They will also leak if they do not match the header or head. Make sure that you have square port gaskets and headers to match your heads.
Some other things to look for... Did you use adjustable rockers or bolt downs? If adj, then re-adj. If bolt down rockers were used, then you may have a lifter or two not pumping up oil to the rockers. Its hard to tell without being there to hear it. Usually when I here tapping, I know to shut my engine off. At 8k rpms, anything and everything can break. Also if you are using adj rockers, make sure one isnt rubbing on the valve cover baffle on that side. If it was me, I would take that valve cover off and look for anything obvious. If you don't see anything obvious, start the car up with the valve cover off to see something then...just my two sense. |
go figure
#8 spark plug boot came off a liitlle causing an arc to the block.....duh....
Threads Similar to: big time tapping
| fuel injector Tapping to loud | dgt_mustang | V6 Mustangs | 11 | November 2nd, 2007 02:57 PM |
| NOISE [ TAPPING ] | PONYMAN | 5.0 Mustangs | 6 | May 14th, 2007 04:33 PM |
| Clicking .. Tapping Noise ... | BlackStang | V6 Mustangs | 30 | April 2nd, 2007 06:05 PM |
| Lifter Tapping... help? | Stan27 | 99-04 | 11 | February 21st, 2007 01:17 AM |
| help..96 cobra tapping | slvrboy | 96-98 | 3 | July 11th, 2006 01:35 AM |
