2 questions NITROUS and PORTING and POLISHING
question 1. do i need to beef up the motor if im guna run a 50-75 shot through the cold air intake. i already have alot of mods but none internals
question 2. about how much would it be to get my 5.0 ported and polished |
also what were the 5.0 GT's RWHP and RWTQ from the factory? and what do u think i have?
a list of my mods are: 1. BBK cold air 2. BE COOL 160 degree therm. 3. BBK SSI manifold 4. Professional products 75mm throttle 5. Fluidyne aluminum radiator 6. JET performance chip 7. Ford Racing 32lb. injectors 8. BBK hi-flow fuel rails 9. BBK underdrive pulleys 10. BBK shotry exhaust 11. Ford Racing 3.73 gears 12. GT-40X heads 13. Moroso breathing valve covers 14. Ford Racing AC / Heater delete 15. MSD Ignition system, wires, and distributor Future Mods: 1. Nitrous Express 50-75 shot 2. Ford Racing Water Pump 3. Street / Strip Drag radials 4. Porting and Polishing |
Why stop with a 75? Hell, why start with a 50?
What year 302? |
I am thinking about 220 or so to the wheels prob a little less. Stock 5.0's depending on year vary I think 10-15hp at the flywheel. RWHP I would say is about 160-170hp for a stock 5.0.
Depending on year, about 225hp and 295ft lbs of torque at flywheel. If you have a stick, you lose about 15% to the wheels and if Automatic, you lose 20% to wheels. As far as the 75 dry shot, I cant see where it would hurt anything. I had a friend who ran a completely stock 5.0 mustang w 250 shot of nitrous for a whole race season and blew it up in the last race of the year. It was also a wet system though.
I would guess around 300 hp at wheels.
Yea my car is a 1990 GT 5.0 5speed...i was just wounderin wat u guyz thought cuz u no i hear horror sotrys about nitrous and then some people live by it. EX. my buddy has a 150 shot on his pro tuned civic and he has used a shot every weekend for the past 2 years no problem. its just that it cooks ur oil. but thats no biggy
Nitrous can be a very easy and fun way to add extra ponies for a small initial cost. The problem with people blowing their shit up with nitrous is the fact that it is much cheaper and easy to install then say a supercharger or turbo. Because of this you have more idiots out there with $600 laying around that say, "Lets go throw a 300 hp nitrous kit on my cavalier" and wam bam thank you ma'am they blow their shit sky high. If you do some research about nitrous and get a nice kit and get the safety devices that help keep your motor together then nitrous is just as safe as a supercharger or turbocharger.
The other problem with nitrous is filling the bottle. Nitrous in most area's goes for about $4 a pound. With a 10 lb bottle which is what most kits come with thats $40 everytime you fill the bottle. Depending on how often you spray this can get costly. I would say with a full 10 lb bottle you will probably get 8-10 1/4 mile passes. Make sure that whatever kit you get, you also get a fuel pressure safety switch, a wide open throttle switch and a window switch. A bottle heater helps with pressure but is not necessary. Also depending on how big of a shot you run, you will probably want to go 1 or 2 ranges colder on your plugs to help get rid of some of that CC heat. If you do these things you can spray a 150 shot of nitrous on your car for a few years. Anything above a 150 shot and I have heard you start to mash the ring landings and then your rings will stop sealing and you will lose compression and start burning oil. Hopefully this helps and will answer some of your questions about nitrous being unsafe. Nitrous can be safe, its the idiots that use it and don't know about it that are unsafe. Another note I just thought of is as you read posts look at how many people you see have trouble blowing head gaskets with superchargers or turbochargers. You almost never see a post about somebody blowing a head gasket with nitrous. I am not 100% on the reason for this but I have some theories. #1 most important is with nitrous your motor is not seeing that added horsepower all the time. With a supercharger or turbocharger it is readily available and causes people to drive that car harder puting more strain on the motor. With nitrous everytime you spray its costing you money so that tends to help most people be more conservative with it I think. Theory #2 is that with boost your actually cramming or forcing compressed air into your cylinder which over time can push out gaskets and cause sealing issues. With nitrous its just a gas that has a higher oxygen content than the atmosphere air but it is not being forced into the cylinder, just fed to it. I think that between these 2 ideas that is why you hardly see any nitrous cars have head gasket issues like you do with turbocharger and supercharger cars. Good Luck
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller 13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock |
2000 GT
slow
port&polish atleast $2500
Hourofpain wrote: girls always think its cute when we try to do stuff that we cant do good idea.. nba.. next time you have a date, take her to a garage and let her watch you work on a car |
1990 LX hatch
Question #2 look up the TMOSS site.
1987 ford mustang gt
well see when shes done
Port and polishing is not 2500 bucks
,where the hell are you shopping
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
#12 | |
a 75 shot uses about .5 lbs in 10 seconds jetted for 75 hp you should get close to 17-20 passes out of a full bottle (with a bottle heater). ex: my buddy just filled his bottle after about 15 passes jetted for 125 and he had about 2lbs left in the bottle. |
Threads Similar to: 2 questions NITROUS and PORTING and POLISHING
| more nitrous questions | TTownZilla | 99-04 | 63 | September 7th, 2007 04:57 AM |
| Porting and Polishing | RandoGT | 96-98 | 37 | August 19th, 2007 09:44 PM |
| NITROUS questions | rkloehn | 5.0 Mustangs | 5 | April 15th, 2007 10:48 AM |
| Nitrous questions | foxstang | 5.0 Mustangs | 21 | March 17th, 2007 11:10 AM |
| Head Porting Questions! | 96greenGT | 99-04 | 13 | November 14th, 2006 09:21 PM |
