My Car Idles Like Shit - Page 2
Old April 10th, 2007, 05:02 PM   #21
fastford3388's Avatar
1991 Mustang GT
fastford3388 is on a distinguished road
Send a message via AIM to fastford3388
I had a similar problem with my 89 GT. It ended up being the EGR Position sensor and the TPS sensor that went bad. Is the check engine light on?
- '90 Mustang LX-Sold "Debbie"
- '89 Mustang GT- Deceased "Lucy"
- '91 Mustang GT-70,000 mi "The Unicorn"
Old May 11th, 2007, 01:53 PM   #22
NoPHONYpony is on a distinguished road
U should check the EGR valve it might give u a shitty idle at low rpms and idle it will prob also be running lean
Old May 13th, 2007, 05:54 PM   #23
93GT's Avatar
93GT is on a distinguished road
for any vaccum leaks what i would do is take a can of brake clean and start your car when its cold and spray where you think there is a leak( all of the lines around your upper plentum) you will here the motor run better if you have a leak in that spot.
Old November 5th, 2007, 12:18 PM   #24
Overkill's Avatar
Overkill is on a distinguished road
Assuming your tune-up is good (if not you need do that first anyway), and you've checked the IAC and TPS (both are easy and part of a decent tune-up) I betcha it's a vacuum leak. There are only about a thousand places for a leak, the most likely have been posted already, but the hardest ones to get to are probably where the problem is, mainly under the plenum, like jsj_297 says.
I once had a vacuum leak that drove me nuts. I eventually tested every single line, connection and component. I found and fixed mostly a bunch of cracked and gashed lines and a leaky smog pump valve, but got no appreciable improvement. Turned out the little ball shaped vacuum reservoir inside the passenger side fender had a crack in it. Got one out of a junker, hooked it up and the problem was over.
1986 Mustang GT
Old November 5th, 2007, 04:04 PM   #25
lugnutz08 is on a distinguished road
Its probably been siad but check the ground from the drivers side head,theys also a green ground between injector #3-4,prolly not the problem but alot of people forget the small stuff
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA
3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH
Old November 8th, 2007, 06:06 PM   #26
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
check the tps and make sure its adjusted properly.
Threads Similar to: My Car Idles Like Shit
idles crazy some times 86ttops 5.0 Mustangs 17 October 13th, 2007 10:50 PM
4.10 are in now car idles really high and wont shift Timm10221 5.0 Mustangs 5 October 12th, 2007 07:00 PM
car idles wierd now 00GT 99-04 7 August 19th, 2007 03:53 PM
idles like shit 91foxhatch5.0 5.0 Mustangs 3 June 21st, 2007 06:04 PM
idles high in neutral and park rkamp V6 Mustangs 3 September 7th, 2006 09:56 AM
