My Car Idles Like Shit
my 89 gt idles like shit, when its cold it idles real rough and dies after cold start, and when its warm it still idles like shit but it stays on and it is completely stock,
that sucks. good story though
ha just messin wit u man, has it always done that or just recently start? if recently have you done anything to the car lately?
![]() A U D I //S4 2000 6MT/TT/AWD Stage 3 in the works.. 460+ awhp 455 lb/ft torque, 500+ awhp on race gas
1999 Ford Mustang V6
how is the routine maintenace? is this something that gradually got worse?
iac, map sensor, tps?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
1989 Mustang GT
I changed my distributer and used carb cleaner to clean the egr and iac, now she starts right up even after sitting all night.
![]() Ported Saleen Vortech Intake BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump Hooker Super Comp Long-tube Headers Fcam Ported Motorsport J302 Heads 30# Injectors 1.6rr 80mm Mass Air 4:11 gears |
changed head gasket and i t did good for a while idled like new for a bout a week but its been this way for a couple of weeks and im gettin damn tired of it
do u think that i could have a vacuum leak maybe,,,?
Look around at you grounds....especially where the lead coming off the neg post to the fenderwell needs to be in good condition, and the connector on the fenderwell itself needs to be clean.
"The gods too are fond of a joke." "If I had only known, I would have been a locksmith. " |
also whenevr i launch at 4000rpm it just falls back over on its face the rpms drop dramatically back down to about 1500 and the car starts to pick up speed slowly, and the tires only turn for about a half a second and then the rpms drop..
you really need to see if there are any codes....think i just fixed mine...something similiar here lately....newly replaced iat sensor was bad
where is the iat sensor on an 89 5.0 with mass air flow
in the intake manifold...
If you have a poor idle in your car... rolling idle...
then you should clean the iac or even (carefully) the maf sensor... these usually get dirty if you have an air filter like a K&N... other than that if you still have a rolling idle, it most likely is a vacuum leak, so check or even replace the vacuum hoses at the back of your intake.
if the i.a. c. has never been changed, then change it. you will be amazed. cleaning something that is already bad does no good
Please read this article from my favorite technical reference Ford Muscle magazine, it would solve your problem:
http://www.fordmuscle.com/archives/2...in/index.shtml |
change the I.A.C.... but first i would check the mass airflow sensor
Look Ma! My First Post!
Hey bro, you need to take the air bypass valve assy. off of the throttle body/intake manifold. Take and clean the crap out of it with tb cleaner.
(be careful not to F-up your gastket.) If that dosent do the trick, check your pcv hoses, both of them for cracks in the turns of the hose, man ive seen litterly 20-30 of them that look fine, until you bend them and they are usually gashed to shit. Mainly the one that goes to the front of the upper plenium is the worst though. This is going to give a severe primary vacuum leak. Also check in general for any other little hoses coming off the upper plenium intake. Ive had to replace dozens of them over the years on various yrs/makes of 5.0 engines. hope that helps some. |
if i were you i'd give it a regular tune up ...
spark plugs wires distributor cap and rotor then start from there and check the timing |
i didn't see all the responses at first bro.... your onto something
'88 LX body '91 GT D/T
8.7 in the 1/8th
Tune-up, air and fuel filters, clean your sensors CAREFULLY!!! w/ parts cleaner, check for a vacuum leak and see what happens.
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
"Hey bro, you need to take the air bypass valve assy"
Don't you mean (essay)?
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
Threads Similar to: My Car Idles Like Shit
| idles crazy some times | 86ttops | 5.0 Mustangs | 17 | October 13th, 2007 11:50 PM |
| 4.10 are in now car idles really high and wont shift | Timm10221 | 5.0 Mustangs | 5 | October 12th, 2007 08:00 PM |
| car idles wierd now | 00GT | 99-04 | 7 | August 19th, 2007 04:53 PM |
| idles like shit | 91foxhatch5.0 | 5.0 Mustangs | 3 | June 21st, 2007 07:04 PM |
| idles high in neutral and park | rkamp | V6 Mustangs | 3 | September 7th, 2006 10:56 AM |
