87 gt upgrade - Forums at Modded Mustangs
post #1 of 8 Old January 13th, 2013, 01:29 AM Thread Starter
87 gt upgrade
Ok so ive had the car awhile and its been sitting around mostly and now that ive got some moneys I'm thinking about rebuilding it. From what I was told it was an 87 mustang and had some motor mods. Only thing I remember is it had a ford f cam and a borla exhaust. But it has a maf and cobra intake. Leads me to believe it has a different motor than original. So what I'm getting at is where are the numbers located on the motor so I can look it up and find out what its from and if the cam is any good for a 320-350 Hp build? My goals for the motor are above Hp numbers and a reliable motor that will last awhile. I'm not working with a ton of money as I need to buy a roller for it , rebuild and test the block as well as some decent used heads. Also I have 373 gears in it with a t5 trans that I want to swap with a t56 so I can use that gas saving gear but still get up and roll when I floor it. . Any ideas are useful to give me a general range with a setup similar to the items listed above.
Thanks
Stang6er is offline
post #2 of 8 Old January 13th, 2013, 02:57 AM
horsepowerjunkie's Avatar
Any gas savings you will encounter swappinng from a T5 to a T56 will be ate up from the cost of the T56 swap, IMO.
For the HP goals you are looking for, I would just use the stock short block with the Trick Flow kit below. Good luck with your build!
Trick Flow® 360 HP Twisted Wedge® Top-End Engine Kits for Ford 5.0L TFS-K514-360-350 - SummitRacing.com
89 LX Black, Dart 363, C4,T76BB, FAST EFI
86 GT Black, Dart 331, S-trim, 4R70W, MSII
82 Capri RS,306, N41, Fox Lake Stage 1 TW,T5,4.10's
73 Dart Sport 340, 410ci, Indy 360-2 CNC+
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
horsepowerjunkie is offline
post #3 of 8 Old January 13th, 2013, 09:37 PM Thread Starter
What else do u think I should get with that kit. I have about 2800 to get some parts and the roller and that would take it all so it would have to wait a little longer so I can do it all at once but it seems like a really nice bolt on kit.
Stang6er is offline
post #4 of 8 Old January 13th, 2013, 10:13 PM
FastStang91Lx's Avatar
What is this roller that you keep talking about. What is it?
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #5 of 8 Old January 13th, 2013, 10:45 PM
You are gona need a 255lph fuel pump, 24 lbs(min) injectors, matching calibrated mass air meter, 70mm throttle body & spacer, and a possible tune & you'll be set!!
01 Ram Quad Cab
03 Grizzley 660
post #6 of 8 Old January 13th, 2013, 11:27 PM
nkausch's Avatar
I am a bit confused as to what you mean by this roller too?
But if you only have 2800 unless you buy used that isn't enough for a t56 swap.
And 350 all motor is a good deal of power from a 302. You'll need a good set of aluminum heads, intake and a good cam.
94 GT Vert
<a href="http://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html"]http://www.moddedmustangs.com/forums/projects/277159-nkauschs-turbo-vert-pic-heavy.html">70mm Turbo Build</A>
nkausch is offline
post #7 of 8 Old January 14th, 2013, 12:55 AM Thread Starter
A rolling body. I have one but its in bad shape and its also a vert which I don't want. I'm thinking about getting a wet shot and I have a f303 cam already and it has a cobra intake that is red(I don't know if that is stock or a aftermarket one that was painted. If anyone knows please let me know.) I don't remember if the Tb is a stock or not. I'm going to start disassemling it either tomorrow or Tuesday and should have a better idea then. Also with the borla exhaust, o/r h pipe what kind of power should I be around now.? If I can manage around 285/350 id be happy cause ill just get a nitrous kit.
Stang6er is offline
post #8 of 8 Old January 14th, 2013, 11:07 PM
demolitionman's Avatar
Drool - if I had the money I swear my car would look great in that kit
1988 LX AOD - Cobra Clone Body - TFS TW Heads - TFS Stage 1 Cam - FRS 4:10 Gears - Mass Air 24lb Inj - 93 Cobra Intake Ported 1" Spacer - BBK 70mm TB - Steeda Pulleys - Racing Pistons - BBK Cold Fender Air - Flowmaster 40s-
demolitionman is offline
Human Verification
