5.0 Will run to normal temp. Die and won't start again. - Forums at Modded Mustangs
post #1 of 20 Old January 13th, 2013, 02:22 AM Thread Starter
Angry 5.0 Will run to normal temp. Die and won't start again.
I have a 1981 Mercury Capri, which is the same as a Mustang, and I can't go out, fire it up drive it about oh.... 2 miles, until it heats to NORMAL temperature. Then, It will die and won't start back. It's losing spark somehow. it won't start until it cools completely.
I'm getting irritated with it, and tempted to send it to the crusher..
List of new parts.
Motor.
Distributer.
Ignition control mod.
coil.
alternator.
Battery.
solenoid.
Voltage regulator.
ANY help would be appreciated.
1981Mcapri is offline
post #2 of 20 Old January 13th, 2013, 02:24 AM
M112'd Sixxer
Sounds like a crank sensor.
Sent from my droid using my fingers.
Garage:
1999 Mustang V6 M112 4R70W (Elise) Sponsored by Ortiz Performance
2013 Fiat 500 Turbo C510 (Rosso Rocket)
Fink is offline
post #3 of 20 Old January 13th, 2013, 02:32 AM
Not sure an 81 has a computer let alone a crank sensor
bigTom1 is offline
post #4 of 20 Old January 13th, 2013, 02:33 AM Thread Starter
It's from a late 70's model Bronco. Do they have crank sensors?
This car came with a 255ci v8. The owner before me changed it to a 302. It ran perfect until I shattered my oil pump shaft through a cylinder wall. it runs like a dream until it heats up. and just bamm. dead. and won't restart until it has cooled off.
post #5 of 20 Old January 13th, 2013, 02:36 AM Thread Starter
And I've not been able to find any computers. I've looked everywhere in it for one.
post #6 of 20 Old January 13th, 2013, 02:39 AM
And like a distributor or ignition control module. I know they are new. I would try again
bigTom1 is offline
post #7 of 20 Old January 13th, 2013, 02:39 AM
Fuel pump also.
bigTom1 is offline
post #8 of 20 Old January 13th, 2013, 02:41 AM Thread Starter
It's loosing spark, not fuel.. I might try the Dizzy... I had the ICM tested for hours, passing flawlessly.
post #9 of 20 Old January 13th, 2013, 02:45 AM
Hmm, crazy man. Do the dizzy again
bigTom1 is offline
post #10 of 20 Old January 13th, 2013, 08:16 AM
narleycarley's Avatar
Went through this with my 91 years ago. I replaced distributor and it was fine for about two weeks then would do it again. Where is your coil located? Anywhere it could be getting hot? Is your coil a good brand?
All I can suggest is getting another distributor from a known good running car and see if that fixed it.
I never could get problem resolved, traded mustang in and now I see it around town sometimes. This was my very first mustang also.
Sent by carrier pigeon
Originally Posted by Chuck Norris
Foxbodies > all
narleycarley is offline
post #11 of 20 Old January 13th, 2013, 08:18 AM
FastStang91Lx's Avatar
That's why some people should just stick to what they know.
No, your car has no crank sensor, nor a computer. I assume that you've checked for spark when it won't start and that's how you know it's spark and not fuel? Check power to coil when that's happening and keep working your way backwards.
FastStang's Ongoing projects thread Click here!
FastStang91Lx is offline
post #12 of 20 Old January 13th, 2013, 08:56 AM
Exhaust fume addict
TBacon's Avatar
^This
Originally Posted by azure mach! View Post
That went from majestic speech to surprise buttsex really quickly
TBacon is offline
post #13 of 20 Old January 13th, 2013, 01:56 PM
4 cam 4 life
NeverEnuff's Avatar
Does this thing have an ECU? Did you convert it to EFI? I know it didn't come factory with one...just asking. There have been several A9L/ECU issues that when the car heats up, it dies and won't restart till it cools. Its a ECU problem. Thats why I asked. If you have the 81 body, then its impossible to put the ECU in the stock location. If someone converted it, then the ECU is chilling someplace else.
I know this may not be much help, esp if you have no ECU. But just trying to help. I went through the same thing with my 91 LX for 2 years. Would die hot, and restart cold perfect. Ended up being the ECU.
Have you verified its spark? Like when it won't start, have you pulled a plug quickly and turned it over checking it?
89 Coupe-Worlds Fastest NA Modular build in progress
http://www.moddedmustangs.com/forums...lar-build.html
01 Lightning-Ported Eaton, Comp 278s, Exhaust, daily
NeverEnuff is offline
post #14 of 20 Old January 13th, 2013, 03:11 PM Thread Starter
No, it's not an EFI. And, narleycarley, It's an accell superstock coil from autozone, was one of the more expensive ones, but it's located on the intake.This link is to a picture of the OLD motor, i don't have a new one on here, but this is where everything is located at.
And, Neverenuff, when it won't start, I tried that. and I can crank all day and not a fire, but as soon as I let off the key, It'll get one shot of spark, but still won't start.
post #15 of 20 Old January 13th, 2013, 03:11 PM Thread Starter
post #16 of 20 Old January 13th, 2013, 03:26 PM
4 cam 4 life
NeverEnuff's Avatar
Roger that. Just checking. Sounds like to me something is getting heat soaked.
post #17 of 20 Old January 13th, 2013, 03:30 PM Thread Starter
That's what I was thinking. But, all the electronics stay actually pretty cool.
post #18 of 20 Old January 13th, 2013, 05:04 PM
85 GT convertible
Old Chryslers wouldn"t start until the key was released because of the starting system balast resistor. I don't believe this car has one but check with something simple like a starter relay and a fuseable link somewhere in the starting system. I may be way off but you might have to think out of the box and let us know what you figure out.
Jerry
deputycrawford is offline
post #19 of 20 Old January 13th, 2013, 06:23 PM
You're coil isn't staying cool right there no matter what you think. I'd move that even if it don't fix it.
post #20 of 20 Old January 13th, 2013, 08:00 PM
Never been a fan of Accel products. I would find a stock coil and agree with the others about moving it.
FormulaFord is offline
Human Verification
