wet shot?
Old July 24th, 2007, 07:48 PM   #1
93 GT Hatch
12.68@112.57
superman5.0 is on a distinguished road
Send a message via AIM to superman5.0
wet shot?
93 5.0 with e cam and bolt ons i know the pistons are not forged cause 93 but what would be the biggest shot i could run without eating a piston?
Old July 24th, 2007, 11:07 PM   #2
1987 ford mustang gt
well see when shes done
I wouldnt put any on it,but lets see what everyone else has to say
347, torn apart again.
Old July 24th, 2007, 11:37 PM   #3
tording92lxnotch is on a distinguished road
Well there is always a chance of causing destruction to a motor when you start throwing more power at it but I am sure that a 90 shot would be extremely safe to spray on it. IF you have it setup right and don't run lean I am sure you would even be safe with a 125 or 150 shot. I would not go over 150 for sure though.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old July 25th, 2007, 12:30 AM   #4
93 GT Hatch
12.68@112.57
ok thanks alot, usually i post this on forums and all i get is people scared of the bottle, but i have had very good results on previous cars
Old July 25th, 2007, 01:38 PM   #5
ryans88gt's Avatar
I've sprayed 150 at a hyper piston motor regularly. Tuning is important. As long as you are not detonating and the A/F is good the hyper pistons will hold up just as good as forged. However, if you are detonating or running lean, forged pistons will give you a much larger margin of safety. So keep that in mind, start safe. Pull timing out, go with a step or two colder plug, get an A/F gauge, run the highest octane fuel possible and READ YOUR PLUGS. If you go about this the right way, you should be able to work your way up to 150 hp and have a good tune. Above all, listen to the manufacturer of the kit you choose. They usually know more than most people on here...
Threads Similar to: wet shot?
125 Shot? SantanielloITA V6 Mustangs 25 November 10th, 2007 03:56 PM
what is the best shot of n20? 40thmustanggt 99-04 10 July 19th, 2007 10:32 AM
Zex wet shot 95wip 5.0 Mustangs 1 May 2nd, 2007 03:30 PM
25 shot GreenFaleen General Tech 81 April 30th, 2007 01:03 PM
how big of nos shot 95StangSVT General Tech 16 February 6th, 2007 10:32 PM
