87 Mustang GT T-top
New Clutch Cable
I got an 85 Mustang GT and i am about to install a new clutch cable ( Kit ). I was just woundering if theres any advice anyone has to help this go smoother. Any brand you recommend, or if there is anything else you recommend that i buy, i heard someone tell me i should make a casing around it and then weld it, Is that all needed? Thanks for any help.
Just put it in? I haven't heard any tricks and I sure didn't use any when I changed mine.
you wont need to put a casing around it if you route it away from the headers by using the supplied bracket.
Use the FRPP cable with a fire wall adjustor, saves crawling under the car to make adjustments. I've heard the Steeda's etc. are weaker and can split.
I used header wrap around the cable where it contacted the long tubes, haven't had any problems in a year. Check the Quadrant for cracks if it's the original, PITA if you replace the cable and it breaks on you. Install instructions http://www.fordracingparts.com/downl...-7553-B302.pdf Good Luck getting it done. |
Threads Similar to: New Clutch Cable
| clutch cable..... | sivart | 5.0 Mustangs | 6 | September 25th, 2007 03:51 PM |
| Clutch Cable | dStoltenberg | 5.0 Mustangs | 1 | June 19th, 2007 01:17 PM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 02:33 PM |
| clutch cable | macnesa23 | V6 Mustangs | 8 | March 6th, 2006 12:10 PM |
