302 351w
Old July 25th, 2007, 09:04 AM   #1
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
302 351w
what parts are interchangeable from a 351w to a 302. i was jsut guessing that the heads, and intake were..i jsut didnt know what else..i aleady have the edelbrock intake manifold, and i just figured why not get used 351w heads out of a 69' windsor..they are probably better than the stock 302 ones.
Old July 25th, 2007, 09:11 AM   #2
neverfastenough1's Avatar
Timing chain cover. The lower intake isn't interchangeable. Water pump?
Old July 25th, 2007, 09:26 AM   #3
yeahh i just figured id slap on the 351w cylinder heads to my 302...are they better than the stock 302 ones?
Old July 25th, 2007, 09:30 AM   #4
Yes they are better. They are what everyone used before the aftermarket exploded. Not as good as aftermarket but better than stock.
Old July 25th, 2007, 09:51 AM   #5
94' Cobra 351's Avatar
94' Cobra 351 is on a distinguished road
Port and polish them!
The water pump is interchangeable...
what other parts are you wondering about?
Old July 26th, 2007, 12:01 AM   #6
i was mainly conerned about the cylinder heads from a 351w...is there a certain year on the 351w motor that stands out better than other years..i heard the 1969 351w is the best year windsor..i dont know if its true or not though.
Old July 26th, 2007, 12:14 AM   #7
woody1 is on a distinguished road
It was a decent head WITH work, in stock form its certainly nothing to write home about, the GT40 and P is a better stock for stock head by far. If you use the 351 you will need stepped arp head bolts since the 351's use a 1/2 inch head bolt as compared to the 302's 7/16 head bolt. Unless they are nearly fresh, the seats and guides are more than likely pounded to death after 30+ years, if thats the case, dont spend any money when you can get reman 40's or P's for 300ish
Threads Similar to: 302 351w
11 Second 351w drthunder7 5.0 Mustangs 21 May 27th, 2007 11:06 AM
351w dragpipe General Tech 2 May 2nd, 2007 07:53 AM
351w mustangrebuilder Classic Mustangs 5 April 2nd, 2007 08:19 PM
351w FastBack71 94-95 6 February 4th, 2007 03:40 PM
351w ecu? 5-0stank 5.0 Mustangs 6 January 7th, 2007 01:13 AM
