What size TB should I use?
I'm going with a GT-40 top end. GT-40p heads, Explorer intake etc. What would be the best size TB to use? 65mm, 68mm, 70, 73 etc.
Thanks |
#2 | |
Re: What size TB should I use?
I put a 65mm on mine.
+1 for 70mm
theres a 68 and 73 mm TB?
maybee the 68 and 73 were maf. i've been looking at too many parts lately!
thanks guys. 65 will work and 70 is better! |
I would go with a 75mm if you still plan on upgrading in the future....
For you r combo I wouldn't go too big. (70 max) TB has to be sized right for the car and your mods, or you can end up having performance problems.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
1990 LX hatch
use the explorer one. its 65mm and its cheap. just cut off the plate that the throttle cable connects to and tack weld on the one from your car.
is there a problem if you go too big? i mean within reason, you obviously wouldn't put a 80mm on a stock setup but would 70 be too big on a stock setup?
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
Downfall of TB being too wide: Potential for more air, but you're getting less velocity.
Basically, if you have a huge opening and you're on a stock motor (or a motor not setup for it), the opening will not be able to actually efficiently suck the air into the motor. Using a smaller diameter TB, the air is forced through a smaller opening and the revese pressure creates a vaacuum in the manifold. It allows the air to move through the intake manifold quicker and more efficiently. Same reason you don't run 5" exhaust from the headers-back |
i've been trying to get the whole explorer set up. someone said that autos may have a problem with the explorer 65mm intake. if any one knows for sure let me know!
Threads Similar to: What size TB should I use?
| maf size? | superman5.0 | 5.0 Mustangs | 5 | July 28th, 2007 08:06 PM |
| What size | scxc15 | V6 Mustangs | 24 | May 27th, 2007 05:09 PM |
| What size CAI | Zellanor | 2005 - 2010 | 1 | January 25th, 2007 10:18 PM |
