1987 Mustang LX 351W
Electrical Issues :( (WITH VIDEO)
Maybe you guys could help me diagnose this problem. Spent OVER 5 hours trying to find the issue but no luck. Been driving me crazy so alot of input from alot of different people would be great!
Will be watching this thread and responding for a while. Any questions feel free to ask to help solve the issue quicker.
351W - Stock Heads - BBK Headers - Edelbrocke Performer Intake - Holley 750cfm Double Pumper w/ Mechanical Sec. - 5 Speed Manual T5 - Stock Rear End - Mallory Ignition Soon To Come - 4 Point Roll Bar - Paint - Wheels And Slicks |
1991 Mustang LX 5.0
Check your grounds under the dash and don't worry so much about the stock volt gauge anyway. You have the aftermarket one. And make sure your dash frame to chassis bolts are tight also. On second thought, just add a ground from chassis to dash frame. Pull it right from the battery if you want.
FastStang's Ongoing projects thread Click here! |
#3 | |
Also my lights and turn signals dont work because i left that connected directly to the efi wiring harness and when the stock gauge voltage drops the lights turn signals and radio shut off :/
1991 Mustang LX 5.0
Like I said, it's probably a ground issue since the aftermarket gauge isn't dropping. That would signal an alternator problem. The grounds for the instrument panel, radio, etc. are are on the underside of the dash on the dash frame. Also make sure your battery to chassis ground is good also. You're gonna have to get under there and get your hands dirty. No one can tell you the exact spot to look to fix your problem. It could be a number of things. Grounds first, then go from there.
Is that alternator from a carbed car? They put out alot less juice then an alternator from an efi car. Almost looks to me like your alternator isnt sufficent enough to run the massive amount of electronics you got in that thing. Just saying if that 351 swap is using a carbd alternator thats possibly only putting out 60 amps then thats your problem
In over my head
1990 GT
Slow?
While I have nothing new tech wise to say (I think these guys covered my opinion well) I must say, that's the best "help" thread I've seen! The video was smart man.
#7 | |
I am curious and probably guessing this is the issue however it seems to be fine at idle. Does anyone know how many amps an aftermarket Double spark ignition box consumes?
87 mustang gt
I have a msd 6a box that pulls 1 amp per 1000 rpm. Idk bout other boxes
Seems like the accessories ran off of the fuse box are taking the hit while the accessories ran off the battery are ok, what is the voltage at the post on the back of the alternator? Then check voltage at the end of the lead from the alternator to see if their is a parasitic loss in the charging cable. Then check the voltage at the fuse box.. Where did you tap into for your aftermarket voltage gauge? It doesn't dip does it?
#10 | |
So the yellow and red wire from the radio are direct? Ran your own ground too then? Just making sure your not using anything from the factory harness
#12 | |
Dont know about the yellow one
Red wire is only for memory, ie clock presets etc. yellow is the actual power wire and if that's ran into the factory harness then that to is ran to the fuse box
just remember under powering electronics is just as bad as overpowering them. Underpowering creates heat. heat is the most common cause of electronic failure
