vacuum...
Everytime i get off the gas the exhaust will pop, like backfiring, so ive heard that it could be caused by running lean when off the throttle. So i trying to see if there is a vacuum leak somewhere....i have a boost guage off my other car and can hook it up to mine and see what it is. I have a lunati cam but i cant find the specs on it, but it is basically the same as the e303 cam.
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
#2 | |
Re: vacuum...
hey
i had sorta the same symptom my car wouldnt idle correctly and it was making the backfire,poping noise clean the MAF, And The IAC There is a neddle in your throttle body release the neddle and screw it back to where it was this made my car idle like a dream any more help let me know PaT #06 |
To check for vacuum leaks, establish you base vacuum at idle. It should be somewhere around 16-18 in Hg. Rev the motor up to 2500 rpms and hold it there. You should see the vacuum drop initially and then increase 1-3 in Hg (to 20 or so). If the vacuum drops and stays down, you have a leak. You can spray throttle body cleaner around the gaskets while watching the vacuum to try to locate the leak.
However, I would guess that backfires in the exhaust are usually due to misfiring or an overly rich condition resulting in unburned fuel in the exhaust. |
#5 | |
#6 | ||
#7 | |||
The power difference will come from the timing bump, not the fuel. The increased octane is just added protection against preignition, which is more likely with the timing bump.
Personally, my EFI car runs 15-16 degrees and I run 89 octane in it with no problems. My carbed car runs 34 degrees total timing with the initial set at about 22-24 degrees and I run 93 in that car with 10.5:1 compression. Really for a stock motor with 9:1 compression there is no reason to run anything other than 87 octane unless you notice preignition is a problem. |
#9 | |
#10 | ||
Check the plugs, don't just rely on your hearing to pick up detonation. Look at the plugs and compare to whatever you can find on-line for detonation. Little flecks (of aluminum) are BAD, rounded electrodes and grounding straps are also BAD. In general, you should be fine at 15 degrees, but better safe then sorry.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
i just put new plugs in there, motocraft
and set the gap at .050...i say put it at 14 and 93oct...but then again i dont want to pay for 93 gas prices.....
i had the exact same prob, and found my timeing to be to low, so i set it to 15 and cleaned out the air filter,, no probs now.
my timing was at 8 so i set it at 14 and it seamed to calm it down a little, im running 89 now. my filter is clean but it still backfire/pop but not as much. i have my spark gap at .050, should i leave it there? or is there something else i could check.
That is a bit wide for the stock ignition I think. Could be causing a minor misfire, try .045 or 0.040.
#16 | |
.050 is ok. i keep mine a hair above that and have had them at .055 with no ill effects. the EFIs ignition is actually very good.
#18 | |
#19 | ||
1990 LX hatch
I made 23 in. of vac. with my mouth. All my buddies could only get 16-18.
I guess that means I have no vacuum leaks?
Threads Similar to: vacuum...
| Vacuum Diagrams? | mixedbreed02gt | 99-04 | 1 | October 24th, 2007 01:58 AM |
| Intake/vacuum | FiveOOH89 | 5.0 Mustangs | 3 | July 28th, 2007 06:19 AM |
| vacuum line | 96gtponyred | 96-98 | 1 | July 22nd, 2007 12:56 PM |
| vacuum leak | DragonFreak | 96-98 | 1 | July 11th, 2007 09:12 PM |
| vacuum lines | 88stang | 5.0 Mustangs | 11 | April 4th, 2006 04:16 PM |
