5lug rearend swap - Forums at Modded Mustangs
post #1 of 10 Old February 14th, 2013, 07:35 AM Thread Starter
Hunt_chevs's Avatar
5lug rearend swap
Im contemplating the idea of swapping in a '98 rearend into my fox. What other concerns do i need to consider such as brake issues.
Hunt_chevs is offline
post #2 of 10 Old February 14th, 2013, 08:53 AM
Resident Know-it-all
nxcoupe's Avatar
If you do nothing, both wheeels will stick out about 3/4" further than they are now. Best way to do it is buy the brakes, order caliper brackets from northracecars.com, and get a set of 5 lug fox-length axles and you are set. I cant stand my wheels sticking out tho
90 GT 393 5 spd, 467 rwhp 480 rwtq > Sold
92 coupe, R/S 308 5 spd > Sold all engine parts off, coyote power coming soon..
93 coupe, 2.3 5 spd > still plugging along...
nxcoupe is offline
post #3 of 10 Old February 14th, 2013, 09:32 AM
Or you could just run an 8 inch wheel in the back im pretty sure. I am planning on the my 5 lug swap in march on my spring break. I have fox length 5 lug axles, the caliper brackets, antimoan brackets, 95 gt rear calipers and ebrake cables, 95gt brake booster/master cylinder...etc.
'87 Sonic Blue 5.0 - Tremec t5
Edelbrock Performer 5.0
BBK 70mm TB + Egr
MSD Ignition
MAC CAI
BBK Shorty Headers
BBK O/R X-Pipe
Mac Produmps
3.73's
A9P -SCT Dyno Tuned
5 Lug / Rear Disc
18" Saleen Reps
BROKE-ASS-COLLEGE-KID CLUB
MattFrancis is offline
post #4 of 10 Old February 14th, 2013, 10:31 AM
I have the cobra brake setup and it was less headache to just put in fox length axles and buy the brackets from lmr.
91 LX 306, AFR's, T5Z, 373, 5 lug real 03 cobra wheel swap with Cobra brakes front and rear, Tokico Ill's, Tokico springs, MM Suspension goodies, MGW Short Shifter
elarm1 is offline
post #5 of 10 Old February 14th, 2013, 10:47 AM
4 cam 4 life
NeverEnuff's Avatar
I just took my stock caliper brackets. Cut a slice in them, swapped sides and slipped them on the inside of the housing axle flanges. Almost perfect for the fox axles and didn't have to buy anything.
But a 96-98 housing/axle will fit not problems other than the wheels sticking out too far.
89 Coupe-Worlds Fastest NA Modular build in progress
http://www.moddedmustangs.com/forums...lar-build.html
01 Lightning-Ported Eaton, Comp 278s, Exhaust, daily
NeverEnuff is offline
post #6 of 10 Old February 14th, 2013, 10:56 AM
Priest of the Car Gods
ReverendDexter's Avatar
You're going to need to swap to a 4-wheel disc brake master cylinder and proportioning valve. I'm also not sure how the e-brake works when you do the swap.
Function > Form, always
ReverendDexter is offline
post #7 of 10 Old February 14th, 2013, 11:01 AM Thread Starter
Hunt_chevs's Avatar
got a pic?
post #8 of 10 Old February 14th, 2013, 11:33 AM
E brake calbes will have to be swapped out as well. If that route will be taken, you will have to swap all the parking brake stuff out and weld the gears of the parking brake
Mustang SVE 5 Lug Disc Brake Conversion: Part 2 - Rear Brakes
elarm1 is offline
post #9 of 10 Old February 14th, 2013, 04:02 PM
PhD in Procrastinology
1BDSTNG's Avatar
Great info. I'll be doing the 5 lug/rear disc swap. @NeverEnuff...I love your avatar
1991 GT- 347ci
2014 GT/CS
Instagram: @1bad_5oh
Originally Posted by Imran View Post
i clamp it with my teeth and hold it in my mouth.
1BDSTNG is offline
post #10 of 10 Old February 14th, 2013, 05:27 PM
ryanw's Avatar
Putting a 8" wide wheel wont fix the problem with the axles being 3/4" longer on each side, in fact it would make the problem worse. The wheel would be even closer to the fender ( im speaking as if the stock bs was used) i believe the solution would be to pick a wheel that has the correct size bs to compensate for the wider axles. Then for the most part you can pick how ever wide of a wheel you want
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
ryanw is offline
Human Verification
