1988 My Way
13.68
![]() iTrader: 2 reviews
Fan/pulley quick help
Need some fast help please and thanks in advance. Doing a underdrive conversion today and I'm trying to pull the fan off to give me some room but can't seem to figure it out - newb I know but how does it come off? I removed the small coil piece figuring it would slide off but it won't. Do I need to remove the pulley screws first and then the rod slides out? Pics attached
![]() ![]() Sent from AutoGuide.com Free App
Building my car my way - 1988 LX 5.0 SD - Cobra Hood - LX Spoiler - Trick Flow Intake - GT40 Heads - BBK 70mm TB - Steeda Pulleys - Racing Pistons - BBK Cold Fender Air - Flowmaster 40s- 4:10 Gears |
1993 mustang gt
Slower than you
I would have just unscrewed the 4 bolts on the pulley side and left the fan clutch alone man. You need to unbolt the 2 bolts on top that hold down the shroud then unbolt the 4 bolts on the pulley that hold the fan on there, then manuver the fan out through the bottom by pulling the shroud up a bit which gives it the clearance.
Your welcome.
1991 Mustang LX 5.0
Like mentioned, 4 bolts on fan that holds it to the water pump. Then remove the shround bolts (two on top) and pull the two out the top at the same time. After you pull those 4 bolts, you need to 'pop' the fan free by pulling it off the snout of the water pump. It will most likely be on there pretty good. Don't slam it to hard forward into your radiator. You'll see what I mean when you get to that point, lol.
FastStang's Ongoing projects thread Click here! |
1988 My Way
13.68
Yeah I figured out I should do the pulley side first and I put the fan bolts back in. Now the problem I'm having is keeping the pulley from turning to wrench the bolts off since there is not enough room for the smallest ratchet. Any tricks?
1993 mustang gt
Slower than you
Hold the fan lol. Thats what I do.
1993 mustang gt
Slower than you
Or if you must get another wrench and put it on one of the other bolts and pull opposite directions until you have them all broke loose enough.
1991 Mustang LX 5.0
Breaker bar between fan shaft and bolt head.
#8 | |
1988 My Way
13.68
Fan/pulley quick helpSent from AutoGuide.com Free App
1993 mustang gt
Slower than you
Glad I could help man.
1988 My Way
13.68
Ok so after all that work taking the majority of the front of engine compartment off I finally got to the point of installing the first new pulley. So I hand turn in all the bolts and low and behold none of my tools will work to torque them down because the heads of the bolts are tight up against the pulley wall. What kind of design is this for god sakes? The only solution I can think of is to go to the hardware store tomorrow and find some bolts the same length and diameter thread but with a smaller head. That should work right?
Second question: on the bottom drive pulley the bolts were really hard to get free. While wrenching on them to get them loose the entire bottom drive would turn. Is that ok? Will it mess with my timing or anything? I know the numbers are on that for timing so it makes me nervous. Sent from AutoGuide.com Free App
1993 mustang gt
Slower than you
Dunno about the first part of the question, maybe you just have some thick walled sockets. If the only way to get to the bolts is by socket then you may just need a thinner socket, if you can fit a wrench in there than that may be your best bet. But on your second question don't worry about it, it's not gonna mess with your timing or mess anything up. I did the same thing when I replaced my harmonic balancer, I did notice a ticking noise once I got everything back together and started it up which scared the living shit out of me but it went away after a couple of revs.
1988 My Way
13.68
Thanks sham - yeah there is no way to fit a wrench in there and I'm pretty sure my sockets are normal sized as I tried both sets - I will figure it out by new bolts or just find a way to work them in tight enough
1988 My Way
13.68
Did some reading around the web and found a few entries about having to get new belts due to the smaller pulley size so that's what I'm going to do. Thanks for all the input.
1988 My Way
13.68
1991 Mustang LX 5.0
Mine have always came with allen head bolts, but I've always only bought the same set each time. And speaking of belt, you may need a new one of them too, seriously. Having the motor turn won't affect anything as your distributor is turning with it. No worries man.
Resident Know-it-all
92 blk/blk coupe
9.70@140
Yes, if you bought them used, then someone kept the bolts. Your originals wont work. You need to go buy some 3/8" allen head socket bolts, 1" long at the hardware store. I buy them in bulk because cust always buy them used and never get the bolts, so I charge them for them.
90 GT 393 5 spd, 467 rwhp 480 rwtq > Sold 92 coupe, R/S 308 5 spd > Sold all engine parts off, coyote power coming soon.. 93 coupe, 2.3 5 spd > still plugging along...
92 blk/blk coupe
9.70@140
Oh and easiest way to break water pump pulley bolts loose is to do it before belt comes off or use a pipe wrench, open the jaws just far enough apart to slide over the edge, tip wrench opposite of direction the you,re turning the wrench, and adjust as necessary.
No, turning the crank pulley doesnt hurt anything. And grabbing the fan blade on a viscous drive fan? Lol itll turns.
#18 | |
1988 My Way
13.68
#19 | |
1988 My Way
13.68
#20 | |
In over my head
1990 GT
Slow?
