Can oil pump shaft be swapped from the top??
i was told that it might be possible to change the oil pump shaft thru the top instead of the bottom of the car. I was told thru the distributor shaft after removing the dizzy i can pull the shaft out and replace.
Is this true? |
i would git it a try as long as you place the shaft back in the oil pump when it goes back in you could do it with a oil primer
If its original from the factory, you can NOT remove it from the top. The washer on the shaft is for this exact reason, so many guys leave the washers off then get pissed and start new threads on forums about how they pulled there distributor and the pump shaft fell in the oil pan.
Threads Similar to: Can oil pump shaft be swapped from the top??
| PI Swapped vs. 99-04 | RandoGT | 96-98 | 23 | October 1st, 2007 08:40 PM |
| drive shaft shop one piece steel shaft ok for automatic tran | mustang fanatic | 2005 - 2010 | 8 | September 24th, 2007 02:21 AM |
| Swapped my New Engine! | oasr87 | V6 Mustangs | 21 | July 24th, 2007 01:43 PM |
| PI Swapped Motor | 98vortech | Modular Mustangs | 7 | September 19th, 2006 06:24 PM |
| oil pump shaft and distributor | 03stanger | 5.0 Mustangs | 0 | July 12th, 2006 06:49 PM |
