rear suspension
Old July 29th, 2007, 01:53 PM   #1
angermgt's Avatar
angermgt is on a distinguished road
rear suspension
just got adjustable uppers and lowers for 89 gt. all bushing are solid , on 255 bfg d/r. looking for info on how to tune for traction. my pinion angle is -1. found info somewhere but was very complicated. help.
490whp/432wtq, V2 13lbs. boost, 3.33 pulley
Old July 30th, 2007, 12:05 AM   #2
neverfastenough1's Avatar
If you measured it right, then -1 is a good place to start with solids. You want to try to get as straight a line as you can thru your driveline under load. With that said, solids don't flex very much. You want to keep it as close as you can without letting it go past 0 under load. Here is a good site with simple instructions. The hardest thing is to find a degreeing wheel. It is easier than using a level though. Good luck.
http://www.baselinesuspensions.com/info/pinionangle.htm
Threads Similar to: rear suspension
Rear suspension mods Wado 2005 - 2010 5 November 2nd, 2007 11:20 PM
Rear suspension noise Veeder 99-04 1 July 23rd, 2007 01:18 PM
83 GT rear suspension radster87 General Tech 1 July 23rd, 2007 02:50 AM
Rear Suspension Cracked Help 2001mustanggt General Tech 2 May 2nd, 2007 12:57 AM
Rear Suspension Help sn-95aac 5.0 Mustangs 3 October 7th, 2006 06:30 PM
