Rear Shock tower Braces
do they do much? i can't find many online, anyone have experience with these on a fox hatchback? where can i get one?
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
Wow!!!
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster . BIVENS RACE CARS FTMFW!!! |
1987 ford mustang gt
well see when shes done
No need for it
Strut bar = fun mod (if you like turning)
Why? Because your spring/shock assembly is not directly connected to the main chassis rails, there is a natural flex on the strut towers during cornering. Your strut bar reduces the flex by tying two parallel strut towers together. This transmits the load of each strut tower during cornering between both towers and reduces chassis flex. I usually do this as one of my first suspension mods. Improved chassis rigidity and you'll see understeer is reduced, tire wear is improved and metal fatigue is greatly reduced in the strut tower area. If you're trying to make turns, its a good mod. |
I have rear tower brace on my 91 GT. I got it from blue oval for about a 100 bucks. It took me about 2 hours to install. I can tell the difference when I go around curves.
The fox uses a solid rear. With a solid rear the need for a brace is almost nothing. It helps with a independent rear swap.
PS: It cant change tire wear.....its solid rear.... |
#7 | |
1990 LX hatch
Threads Similar to: Rear Shock tower Braces
| Shock Tower Brace | 06GTMustang89 | 2005 - 2010 | 1 | November 12th, 2007 05:04 PM |
| Struct Tower Braces | Garhfer | 99-04 | 2 | October 27th, 2007 11:36 AM |
| 85 front shock tower brace? | acg | 5.0 Mustangs | 1 | August 23rd, 2007 05:07 PM |
| Strut Tower Braces | bigbadwollfff04 | 99-04 | 7 | April 12th, 2007 04:46 PM |
| Shock Tower Rust | terribleonexx88 | 5.0 Mustangs | 2 | November 2nd, 2006 11:06 PM |
