92 Mustang Lx 5.0 not running right please help - Forums at Modded Mustangs
post #1 of 23 Old March 1st, 2013, 01:37 PM Thread Starter
I need some help, my 92 mustang Lx 5.0 convertable is not running good. It seems like a miss but every time it has a miss the fuel pressure drops as well. I have replaced the fuel pump, filter. Checked the relay, throttle senser destributer and coil and the timing is right new spark plugs and fairly new wires. Has anyone had this problem before problem before and can help me solve it before my head explodes? Has this happened to anyone and if so what is the fix? If you need more info ask and i will try to provide it.
Graves5.0 is offline
post #2 of 23 Old March 1st, 2013, 06:25 PM
ryanw's Avatar
Post the video here
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
ryanw is offline
post #3 of 23 Old March 1st, 2013, 07:29 PM
Resident Know-it-all
nxcoupe's Avatar
wow, so many variables. Is the fuel pump losing power when the fuel pressure drops?
90 GT 393 5 spd, 467 rwhp 480 rwtq > Sold
92 coupe, R/S 308 5 spd > Sold all engine parts off, coyote power coming soon..
93 coupe, 2.3 5 spd > still plugging along...
nxcoupe is offline
post #4 of 23 Old March 1st, 2013, 08:32 PM Thread Starter
It is a new fuel pump but can't hear anything different. When i turn the key it sounds fine.
---------- Post added at 07:32 PM ---------- Previous post was at 07:30 PM ----------
I will post a video tomorrow afternoon.
post #5 of 23 Old March 2nd, 2013, 12:48 PM Thread Starter
post #6 of 23 Old March 5th, 2013, 11:11 AM Thread Starter
Has anyone heard of this?
post #7 of 23 Old March 5th, 2013, 02:49 PM
ryanw's Avatar
Were you pushing on the gas to get it to 2000 rpms or did it do it on its own.
Ive never seen that, sorry i cant help
255 fuel pump,
3:27 gears
ryanw is offline
post #8 of 23 Old March 5th, 2013, 03:22 PM
demolitionman's Avatar
He has to be stepping on the gas when I climbs to 2 no? Have you tried adjusting the idle with the throttle body? Have you looked to see if the. TB needs to be cleaned?
1988 LX AOD - Cobra Clone Body - TFS TW Heads - TFS Stage 1 Cam - FRS 4:10 Gears - Mass Air 24lb Inj - 93 Cobra Intake Ported 1" Spacer - BBK 70mm TB - Steeda Pulleys - Racing Pistons - BBK Cold Fender Air - Flowmaster 40s-
demolitionman is offline
post #9 of 23 Old March 7th, 2013, 03:15 PM Thread Starter
TB is clean, and when at idle it is smooth only for a few min then it starts. When i step on the gas it gets real bad and that is when fuel pressure gage start to drop when the tac drops. It has a new fuel pump in it and it did not help any.
---------- Post added at 02:14 PM ---------- Previous post was at 02:13 PM ----------
The fuel pressure gage will go from 35 psi to 30-25 psi everytime it has a miss of some sort.
---------- Post added at 02:15 PM ---------- Previous post was at 02:14 PM ----------
Could there be air getting in the gas line somewhere causing this to happen?
post #10 of 23 Old March 7th, 2013, 03:22 PM
In over my head
dbshea's Avatar
Codes?
dbshea is offline
post #11 of 23 Old March 7th, 2013, 03:24 PM
I bet money it's a lean spot, not a miss. Go floor it. If it pops through the intake it will give you a good idea. Diaphram in the fuel pressure regulator probably went bad.
flattusmaximus78 is offline
post #12 of 23 Old March 7th, 2013, 10:38 PM
I know it's a repeated question but did you try to adjust the TB screw?
post #13 of 23 Old March 8th, 2013, 04:39 PM Thread Starter
Not throwing any codes and yes on the screw.
---------- Post added at 03:39 PM ---------- Previous post was at 03:38 PM ----------
Is there away to test the fuel pressure regulator?
post #14 of 23 Old March 8th, 2013, 05:23 PM
narleycarley's Avatar
Re: 92 Mustang Lx 5.0 not running right please help
That video was kinda rough with the door chime going on, but from what I could tell it was wanting to skip around 2k, which makes me think TPS. If you gradually increase rpm and it gas a bad spot then its probably TPS.
But with you mentioning your fuel pressure maybe its your regulator. Is your pressure going down when on the gas? Or is it staying down constantly when you are rough running? What pressure regulator are you running? I THINK you check regulator by having a pressure gauge hooked up and with the vacuum hose disconnected and plugged you see what you are reading. Normal is about 38lb. If I remember correct.
Originally Posted by Chuck Norris
Foxbodies > all
narleycarley is offline
post #15 of 23 Old March 8th, 2013, 06:17 PM
In over my head
dbshea's Avatar
Just cause the light isn't on doesn't mean it's not storing codes.
Pull the vacuum hose off the fpr and give it a sniff, raw fuel smell is bad.
Function is checked by hooking up the pressure gauge to the Schrader valve on the return line, vacuum off. Make sure you cap the line so you don't have a leak.
Have you done the base idle reset?
dbshea is offline
post #16 of 23 Old March 8th, 2013, 10:24 PM
Yeah it's almost like the tps is being taken off the way it shoots up like that I'm thinking tps too
---------- Post added at 09:24 PM ---------- Previous post was at 09:21 PM ----------
Graves if it turns out to be the tps let me know I have a extra one you can have for the cost of shipping.
post #17 of 23 Old March 9th, 2013, 09:30 AM
Mine does this right now when I floor it. Havn't had much time to get it figured out yet. Car runs rough.
Foxbodies > all
post #18 of 23 Old March 9th, 2013, 10:47 AM
In over my head
dbshea's Avatar
Now, I may be way wrong here, but if the fpr crapped out it would RAISE your fuel pressure causing an extremely rich condition. I just went thru this (sorta) on my build.
dbshea is offline
post #19 of 23 Old March 9th, 2013, 12:50 PM
No idea. And maybe that's what's wrong with mine is it's running rich like I have it set to high. I dunno, the car sits alot now, I needs to get to the old girl!
OP, how's yours coming?
Foxbodies > all
post #20 of 23 Old March 9th, 2013, 01:00 PM
nxcoupe's Avatar
Not if its leaking. It will lower pressure as it leaks.
nxcoupe is offline
Human Verification
