Where to hook boost gauge on paxton
Old July 30th, 2007, 03:54 PM   #1
nasty92LX's Avatar
nasty92LX is on a distinguished road
I have my boost gauge hooked up on the head unit and i was told it is not so post to be hooked up there .
Old July 30th, 2007, 04:19 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
I have mine attached to the factory vacuum tree that is mounted on the firewall.
Old July 30th, 2007, 10:34 PM   #3
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
just curious where on the head unit did you hook that? I have a paxton and theres nothing on mine, i hooked mine into the tree thats on the fire wall also. I just used the one that was capped off seems to work just fine.
Old July 30th, 2007, 11:39 PM   #4
nasty92LX's Avatar
i have a older sn 89. it is right where the intake tube is how many in from the center is you boost gauge hook on the tree.
Old July 31st, 2007, 09:08 AM   #5
nolife's Avatar
91GT, 88GT, 02GT
Mine is on the second one but that does not matter. All the boost gauge is doing is measuring vacuum and/or boost. You can attach it to just about any vacuum line and it should be fine. If you only have a boost gage (like 0 to 15 lb or similar), you will only see positive boost, if you only have a vacuum gage (like -30 to 0), you will only see vacuum, if you have a vacuum/boost gage, you will see the entire range negative and positive (like -30 to +15 or similar). If you decide to switch gages later, you can use all of your existing work and lines you already put in for your current gage.
Not sure what the port on your Paxton is for and why it is suggested to not use it for a gage. Maybe it is tied to the compressor output and can be used as an "accurate" source for an FMU or a boost retard which both are boost sensitive? Again, no idea.
Old July 31st, 2007, 11:19 AM   #6
nasty92LX's Avatar
ok thats i will do that.
Old July 31st, 2007, 11:22 AM   #7
nasty92LX's Avatar
i ran 14.20 @ 98mph when there was no charger on it. Im running 5-6 psi i was wondering what should i pick up.
Old July 31st, 2007, 12:13 PM   #8
nolife's Avatar
91GT, 88GT, 02GT
Another thing to consider. With boost, you have to be more concerned with detonation. You may have to reduce your timing a bit. Stock is 10 degrees. Most people take it closer to 15. Although I have no experience with 5-6 lbs and your engine, I would think the factory setting of 10 degree would be a good starting point and you can raise it from there. Either way, keep that in mind.
Old July 31st, 2007, 12:17 PM   #9
nasty92LX's Avatar
yea i have it a 17 and it was fine there was no detonation but i put it back down to 10 to be safe
Threads Similar to: Where to hook boost gauge on paxton
o2 sensor gauge hook up noppe180 96-98 22 September 30th, 2007 08:05 PM
Boost gauge question?? jam77 General Tech 7 June 25th, 2007 11:33 AM
Boost/Vacuum Gauge troy1000rr General Tech 1 April 21st, 2007 02:51 PM
Vaccuum/Boost Gauge! jerb43 96-98 1 October 22nd, 2006 03:53 PM
"How to hook up a boost gauge" where do i tap int Fast Stang General Tech 1 April 28th, 2006 11:26 AM
