95 GT not getting any spark.... please help
Old July 9th, 2006, 09:37 AM   #1
Muchavio is on a distinguished road
I have a 95 GT stock, I gave it a tune up,(cap/rotor, plugs, wires) it ran for about 3 weeks to a month, now it won't start. I was told the coil was bad, replaced it also replace the ignition module, still no spark. The battery is new. A mechanic friend of mine checked for codes with the scanner but no fault codes in the ECM. He says it could be the oil pressure sensor that's causing the ignition to shut down. That didn't sound right to me, so I'll ask...Would a bad oil pressure sensor do that? If not, what else should I be looking into? Thanks in advance.
Muchavio
Old July 9th, 2006, 10:10 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Check the pick up coil in the distributor. Also check to make sure the rotor moves when you turn the engine over.
Old July 9th, 2006, 10:26 AM   #3
Darrell, thanks for the reply. The rotor spins when trying to start the engine. Is the pick up coil inside or under the distributor base?
Old July 9th, 2006, 02:16 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The pick up coil is under the rotor. If you have no spark at the coil you need to work your way backwards. Check for power to the coil, if there is no power there keeping taking a step back until you find out where the power is being lost.
Old July 11th, 2006, 08:40 AM   #5
Darrell, thanks. What would be the next thing to check after the coil? Does this site have a diagram/layout of a 5.0 motor and electrical system? If not, what site does? Thanks in advance
Old July 11th, 2006, 09:50 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I'm not sure if there is a diagram here but you should be able to find one at a local parts store in a Haynes manual.
Threads Similar to: 95 GT not getting any spark.... please help
NEED HELP Please. NO SPARK AGAIN noyz25 5.0 Mustangs 9 August 15th, 2007 06:08 PM
No Spark???? brent_cosenza 99-04 11 April 16th, 2007 08:41 AM
car won't get a spark... Philly V6 Mustangs 14 March 24th, 2007 04:46 PM
no spark blackstang333 5.0 Mustangs 10 March 22nd, 2007 06:07 PM
No Spark need help Booger 5.0 Mustangs 4 December 30th, 2006 12:30 AM
