Idling problem
What are some things that may cause my engine to be idling rough? Its a 1990 LX 5.0 with 72,500 miles. only mods are CAI and flowmasters. it was idling rough even before i put the CAI on. i have used some fuel injector cleaner, which improved it a little bit. do you think it could be the oxygen sensor? thanks for any info!!
Did you do plugs,wires,throttle body cleaner. i would try new oxygen sensor or idle positioning sensor.
don't waste your $$$ guessing at which parts need to be replaced.Check for Codes
also you might want to Set your Timing and do the Base Idle Reset let us know what codes you get |
Thanks Tengram,
I'm going to try getting the codes this afternoon, i'll let you guys know what comes up. |
clean the idle air control valve on the throttle body
Threads Similar to: Idling problem
| Idling problem | dothedew1654 | 94-95 | 9 | November 3rd, 2007 05:01 PM |
| idling problem | 02MiNeRaLgRaYGT | 99-04 | 6 | October 19th, 2007 06:29 PM |
| Idling/Ding Problem | fuanfwab | 5.0 Mustangs | 2 | August 2nd, 2007 03:22 PM |
| idling | afmustanglover | General Tech | 7 | April 4th, 2007 10:39 AM |
| My 86 idling | 5literJeff | Videos | 1 | January 18th, 2007 05:26 PM |
