leaky
is it normal for oil to come out when the back of the motor is leaning back does not leak when it is level thoe just wondering thanks
1988 Mustang LX Turbo
can you be a bit more specific?
like do you mean if its sitting on a hill?
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
when i had it sitting at a angle / the oil just started dripping out but after i got it bolted in and sitting level it was fine but yes like it was on a hill front of the car poiting towards the top
1989 Mustang GT
Can you tell where on the engine the oil was coming from? Maybe oil pan gasket or rear main seal? Maybe the dipstick hole?
He is no fool who gives what he cannot keep to gain what he cannot lose." Jim Elliot ![]() Garage: http://www.moddedmustangs.com/forums...-member-10915/ |
well thanks for trying to help i think ill waint till i get it running to see if it hold if it does then i have nothing to worry about
1987 ford mustang gt
well see when shes done
We can help you if you tell us exactly whats goin on. We just need all the little details.
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
1989 Mustang GT
Well the down side to that is if you put the motor in and it does still leak, you may have to turn around and take it back out. That would suck! I would run it down before you put the motor in. Just a thought.
#8 | |
Rear main seals going bad are common in these cars...Locate the problem and fix it before putting back together.
If you dont fix it more than likely your screwed,worst thing you could do is hope that it wont leak.They dont leak for no reason and they dont fix there self.Do it right the first time where you dont have to go back and do it over again,you will be so mad if you have to pull the motor back out to put a new rear main in it.
Threads Similar to: leaky
| leaky? | patwrecked | General Tech | 2 | September 2nd, 2007 08:08 PM |
| leaky sunroof | 91bluestang | 5.0 Mustangs | 8 | July 8th, 2007 10:05 PM |
| My top is leaky | Nick_Rapitis | V6 Mustangs | 4 | May 10th, 2007 03:44 AM |
| leaky trans? | locknest | V6 Mustangs | 3 | February 27th, 2007 06:42 AM |
| Leaky injectors | Hotrodvdog | 99-04 | 2 | April 20th, 2006 08:28 AM |
