Motor Mount install on 90lx coupe.
Old August 2nd, 2007, 06:06 AM   #1
1990LXCOUPE is on a distinguished road
Hey fellas what up!! Got a question. I have a 1990 lx coupe (auto) Long story short, I put on a 75mm throttle body and come to find out my hood will not close beccause of the clearance from the top of the throttle body. I found out that I have after market solid motor mounts which is pushing the motor up a bit. I bought the stock replacements and am anxious to put them in to lower the motor a bit to close my hood. How hard on a scale of 1-10 is this? The other question is, I have a flaming river rack in the car and im told that this is adjustable, because of the header clearance once I lower the motor. Is this true? If so, does that mean it is adjustable like side to side?? Oh, I do not have a plenum spacer for my TF upper and lower.
Thank you for any tips and or advice on this.
Old August 2nd, 2007, 10:34 AM   #2
jtillery is on a distinguished road
I can't really help you on the motor mounts, when we did mine we were pulling the engine anyways so we disconnected everything. If you can lift the engine enough without disconnecting stuff it would be pretty easy.
I also have a flaming river manual steering rack and there isn't any adjustment to raise/lower the rack or steering shaft. The only adjustment is the length of the steering shaft, and that wouldn't affect header clearance. I can take a closer look, but with aftermarket shorty headers, I don't think the steering shaft is even close to touching the rack.
Current Mustangs:
2004 Cobra Convertible
1993 5.0 LX Hatchback
1992 5.0 LX Convertible
Old August 2nd, 2007, 10:47 AM   #3
Thanks for the reply. I will be keeping the engine in place or atleast lifting it with a jack, I figure I would put a phone book between the jack and the engine for padding. The only way to get see is if I get in there and do it. Here goes nothing! I will try today and keep you posted. Thanks again.
Old August 2nd, 2007, 11:05 AM   #4
You are going to have to lift the engine at least a couple inches to replace the motor mounts. I don't think it will be possible to do it with a floor jack, and it if is, I doubt the oil pan would take the weight of the engine. You may want to do a little more research before you try it, seems risky to me. An engine hoist would be the way to go.
Current Mustangs:
Old August 2nd, 2007, 12:26 PM   #5
purplepeopleeater's Avatar
purplepeopleeater is on a distinguished road
we jacked up on mine but i have a serious ass pan, but the hoist would be the way to go. but it can be done with a jack and a piece of wood
Dart sportman, Oliver billet rods, Scat billet crank, Ross Pistons 363ci, 13-8 comp dart pro 1 cnc heads, super vic n race demon, Kooks headers. set in side the pURple PeopLE Eater
Old August 2nd, 2007, 03:25 PM   #6
BLACKNIGHT5.0 is on a distinguished road
Send a message via Yahoo to BLACKNIGHT5.0
PIECE OF CAKE!
JACK STANDS,ENGINE HOIST, AND ALLOT OF PATIENCE... YOU MIGHT HAVE TO BREAK LOOSE YOUR TRANNY MOUNT TOO.......GOOD LUCK
have you chased A FORD LATELY?
Old August 2nd, 2007, 04:02 PM   #7
TurboLX's Avatar
1988 Mustang LX Turbo
save the trouble and buy a cowl hood
Old August 3rd, 2007, 07:27 AM   #8
I would love to buy the hood but being in Hawaii we cant find any and shipping is like $200.00 and the hood I want 1 1/2 is like $200.00 to $250.00. I really dont want all the vibration either. Thanks though, I will let you all know how it came out.
Threads Similar to: Motor Mount install on 90lx coupe.
03 04 cobra motor swap 2 91 coupe? kngkahious 5.0 Mustangs 32 October 23rd, 2007 03:27 PM
Motor Mount Locations GTpwrdCapri Modular Mustangs 4 March 2nd, 2007 08:59 AM
metal solid mount or poly motor mounts? knskit 5.0 Mustangs 5 February 16th, 2007 06:54 PM
Broken Motor Mount Euroeater95 94-95 1 November 2nd, 2006 11:56 AM
Difference between Convertible and Coupe Motor mounts on 5.0 83 5.0 5.0 Mustangs 2 August 16th, 2006 01:59 AM
