HELP !!!!! 14.13 @ 100mph with supercharger
Old August 2nd, 2007, 03:45 PM   #1
nasty92LX's Avatar
nasty92LX is on a distinguished road
I just put a paxton sn-89 on my car it has a 6psi pully. I normaly go 14.20s @ 98mph. I do not have the fmu hooked up. Will that not let the supercharger work right. I do not have any vac leaks either. The vac reads between 20 and 15 at idle. I dont know what els it could be.
Old August 2nd, 2007, 04:00 PM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
well vac is at normal
and theres problably something wrong with your tune
whats your fuel setup?
Old August 2nd, 2007, 04:01 PM   #3
nasty92LX's Avatar
it is all stock
Old August 2nd, 2007, 04:21 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
Are you getting any actual indicated boost? Any pinging or other indications that you are running lean?
Although the FMU does not directly effect the SC, it does provide more fuel under boost. Not sure how much multiplication you would need with 19# injectors with 6# boost though.
Without a fuel pressure gage and wide band A/F gage in the car that you can monitor closely while under load, you will never know what is going on in there. I'd suggest a dyno tune before something goes terribly wrong.
Old August 2nd, 2007, 04:23 PM   #5
nasty92LX's Avatar
okk it does not ping or anything
Old August 2nd, 2007, 05:44 PM   #6
TurboLX's Avatar
dude its simple, Upgrade the fuel system
Old August 2nd, 2007, 08:51 PM   #7
theninja's Avatar
theninja is on a distinguished road
Vaacuum is normal?
I thought that when you "boost" you have no more vaacuum? You aren't relying on the sucking air in anymore, you're forcing it in.
Vaacuum = negative boost
I could be reading your post wrong or just be confused myself, but I don't think you should see any more vac. when you properly get boostin'.
EDIT: NM, I'm just confused myself.
1986 Mazda RX7 (302 cubic inches soon)
2000 Subaru Impreza 2.5RS
Old August 2nd, 2007, 09:20 PM   #8
1987 ford mustang gt
well see when shes done
Did it hook good.
2004 tahoe z71 Daily
2004 BBM Gto ls1 6 speed 57,000 miles
1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600
Old August 2nd, 2007, 09:27 PM   #9
baine21225's Avatar
i'd guess it's the fuel system
Old August 2nd, 2007, 10:31 PM   #10
nasty92LX's Avatar
it hooked fine i still have a 3.27 rear. Max boost goes up to 4 1/2psi. I will upgrade the fuel system. Im new with a super charger so i do not know much about them.
Old August 2nd, 2007, 10:38 PM   #11
88dragstang is on a distinguished road
what was your 60 ft time and 1/8 mile time?
Old August 2nd, 2007, 11:14 PM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
Originally Posted by theninja
Vaacuum is normal?
Most all forced induction engines make vacuum at idle and higher, depending on the SC, or turbo size and trim. some don't make +boost till higher RPM, or load. Some make it at lower RPM, load, but they all make vacuum at some point.
Old August 2nd, 2007, 11:47 PM   #13
TurboLX's Avatar
Forced induction or not, Vac will remain the same unless theres a leak, my turbo doesnt spool up till about 3200rpms and immediatly shoots right to 27psi and then back down to 0 when coasting and then at idle in between 27 and 30 vac
Old August 2nd, 2007, 11:56 PM   #14
JBIGBOOTSY's Avatar
1990 LX hatch
Check vacuum lines, they may be cracked and not leak under vac. but open up during boost. 4.5psi with a 6psi kit, I would only assume that theres a leak somewhere.
Old August 3rd, 2007, 10:38 AM   #15
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Originally Posted by nasty92LX
it is all stock
No way u put a supercharger on your car with the stock pump and injectors...
Old August 3rd, 2007, 11:01 AM   #16
nasty92LX's Avatar
yes way i did
Old August 3rd, 2007, 11:38 AM   #17
thats not a good idea...I'd recommend you go get a nice 255-lph pump, AT LEAST 30 lbs/hr injectors and an adjustable fuel pressure regulator. Your engine is probably running dangerously lean right now. U could break something running lean like that. Im surprised u lasted down the quarter like that.
Old August 3rd, 2007, 12:19 PM   #18
nasty92LX's Avatar
i have a air to furl gauge and it says its running fine i ran it down the track and shut if off after the traps and pulled a plug and it looked fine
Old August 3rd, 2007, 12:50 PM   #19
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
The injectors are fine at that boost level i have a charger running 6 psi and i have no problems. I did upgrade to a 255 lph pump and a adj regulator. I would get a tune or possibly a fmu.
Old August 3rd, 2007, 01:38 PM   #20
TurboLX's Avatar
it maybe fine at idle but once it start's going in higher in RPM's, the fuel is gonna cut out and and not be able to give as much fuel as the engine needs
Threads Similar to: HELP !!!!! 14.13 @ 100mph with supercharger
supercharger scubasteve041186 General Tech 3 September 17th, 2007 12:44 AM
What SuperCharger should i Get? RX Bandit 2005 - 2010 7 September 4th, 2007 07:59 PM
NEED HELP WITH SUPERCHARGER BuitGT 99-04 8 July 17th, 2007 11:13 AM
I topped out a 100mph Drixops V6 Mustangs 42 February 7th, 2007 02:14 AM
Watch me do 0 to 100mph in 10 seconds on this video........ Bossman 2005 - 2010 5 January 30th, 2007 07:03 AM
