top end kit...
I think i've finally decided where I want to go with my car. I want to get a top end kit and a supercharger. I hope to make some where around 350-400 hp. I'm starting to save for a top end kit first but i'm not sure where to start. I was thinking about going with the ford racing kit with gt 40 heads and cobra intake etc. I was also considering the trick flow kit as well. which would be a better start for my setup? i know i'll need to replace the fuel injectors and pump as well. i hope to have the car completely finished in a few years.
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
1988 Mustang LX Turbo
IMO i would go with the Trick Flow, to me it seems like it has more to offer
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
#3 | |
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
im not sure how much power the Cobra kit will give, but more people preffer the Trick flow kit, the intake alone has larger ports
had a Trick flow kit on my 347, pulled 411
1987 ford mustang gt
well see when shes done
How much compression did it have,any poweradders
2004 tahoe z71 Daily 2004 BBM Gto ls1 6 speed 57,000 miles 1987 mustang hatch,347,world heads,systemax, kooks lts,nitrous, 6 point cage, team z front and rear suspension,8.8, 4.10s, 31 splines strange axles,wilwood brakes, tko600 |
+ 1 to trick flow
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
Trick Flow, Edelbrock, maybe some combo matched with AFR 165-185 heads...
The aluminum GT40 heads arent a bad flowing head, but as stated, the intake isnt as good as the Trick flow intake...Spend a couple hundred more and get the Trick flow or similar kit.
Where is the best place to find a top end kit, H/C/I? What brand do people suggest, or is it better to buy parts and pieces from different brands?
That's what I thought, but I wanted to be sure
Because I'm the best there is at what I do, and what I do best isn't very nice. |
thanks man i was just curious,i can see how it made all that power now
how big is the throttle body opening on the trickflow intake??? bc im having this same debate
i never liked top end kits its better to get sperate peices. edelbrock performer intake with rhs 180 heads and steeda #19 cam. unless you want a cobra intake then get it ported.
75mm
50resto.com is often cheaper then jegs or summit and they olny have mustang parts so u no they r good i buy from there and they can answer any tec ?s u have bc most them guys have foxes and work with that stuff everydayi like summit also
do u think that the twisted wedge heads are better then the gt-40x heads?
#18 | |
Trick Flow has the best heads, and the kit is pieced together with parts that were made to work together. The Trick Flow kit has gone up in the past 2 months from $2199 to $2499, so I hope it doesn't keep going up. The Trick Flow kit has been proven to supply up to 70 hp straight out of the box. Holley has a kit for the same price, but I would get the Flow's because the Holley intake has a habit of sucking oil out of the motor.
#20 | |
