suspension vs. E.T.
alright i am in the process of changin to all new suspension consisting of Rear:wolf racecraft adustable upper control arms, lakewood lower control arms, 4 cyl springs and 50/50 drag shocks Front: QA1 tubular k-member tubular a- arms, and coil over conversion with QA1 struts....how much should this take off my E.T.?
1990 LX hatch
what rate are the front springs?
150 or 200 pounds...what would you recomend?best for drag racing
1990 LX hatch
150 is kinda soft unless you have a bit of weight removed from the front. 200 should be more of a stock stiffer feel. I'd go with the 150s for the strip. and if they bottom out on the street switch them for the 200s if they don't bottom out I'd leave them.
you might not shave that much off your ET, but you really want to look at your 60'. that will tell you how well your launching. once you get your suspention, and gearing locked in, you'll be able to make the most out of any HP mods.
Threads Similar to: suspension vs. E.T.
| best suspension set-up for a 2.3 | MSO | General Tech | 7 | July 6th, 2007 07:38 PM |
| new suspension | dadesolja | General Tech | 3 | June 12th, 2007 01:45 AM |
| SUSPENSION | Pony_with_an_attitude | 5.0 Mustangs | 15 | March 27th, 2007 11:51 AM |
| Suspension | dr.gonzo! | 5.0 Mustangs | 0 | January 24th, 2007 12:58 PM |
| suspension | 9stang1 | 5.0 Mustangs | 2 | January 3rd, 2007 09:20 PM |
