What Fluid do you use in your T5 Tranny?
Just wondering what ya guys are using. I want to change the fluid in mine but dont know what to use.
What year? If its a 83-84 it uses 70w gear oil. If its 85+ it uses ATF. It uses ATF for the purpose of lubricating the needle bearings the gears ride on. Use a synthetic ATF. Pre 85 were non world class with no needle bearings, hence the heavier oil.
DO NOT USE SYNTHETIC AFT IN A T-5!
Its lubricates to much and the syncros will no slow down between shifts and it will grind. No synthetic ATF only. |
1990 LX hatch
I use the blood of the innocent.
1987 Mustang GT
You really cant use synthetic in a t-5, i was going to put royal purple in mine. Good thing i read this!
Huh, well glad you said something. Those idiots over at Modern Driveline recommended synthetic. Thanks.
I emailed them to ask if they new what the heck they were talking about. Called D&D and they said use Dexron III.
Threads Similar to: What Fluid do you use in your T5 Tranny?
| Tranny Fluid | armymike63b | 99-04 | 7 | November 12th, 2007 11:27 PM |
| tranny fluid | fsttang96 | 96-98 | 7 | October 27th, 2007 11:31 PM |
| tranny fluid | 96gtponyred | 96-98 | 4 | August 8th, 2007 05:49 PM |
| tranny fluid | Mustang RacR94 | V6 Mustangs | 1 | April 29th, 2007 11:18 PM |
| tranny fluid | terribleonexx88 | 5.0 Mustangs | 20 | November 24th, 2006 06:41 PM |
