2000 GT
Custom Brake's sticking. HELP!
Well I bought a 1993 4 cylinder mustang, did the engine and tranny swap.
I also at the same time replaced the front spindles with 1996 cobra spindles with 1996 GT caliper/rotors (Also making the car 5 lug) I changed the rear out to 1986 SVO rear DISC calipers and rotors, as well as axles. For my stock proportioning valve, I used fords plug kit to plug it effectivly making it a distro block, and ran the rest of the plumbing threw a adjustable proportioning valve. Now my brakes the car etc, works pretty well, except after about 10-15 minutes of driving the brakes start to stick, like pressure is getting to them but never returning....HELP!!! Any Idea's? |
1988 Mustang LX Turbo
your robbed an SVO for it's rear?
You need to rot in hell.... did you happen to bleed the brakes? whats the dimensions of the rotors?
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
Threads Similar to: Custom Brake's sticking. HELP!
| sticking lifters | stephen | V6 Mustangs | 1 | October 18th, 2007 11:48 AM |
| Throttle sticking? | 89StAngerLX | 5.0 Mustangs | 14 | September 5th, 2007 09:50 AM |
| Back breaks sticking | Juggalo_X | V6 Mustangs | 26 | August 31st, 2007 10:11 AM |
| 2002 Mustang GT sticking speedometer | fasterfrank | 99-04 | 2 | June 4th, 2007 05:24 PM |
| Power Lock Is Sticking... | Itrorev | Audio/Video | 7 | March 16th, 2007 10:30 AM |
