Blower Motor not working
Old August 4th, 2007, 01:44 PM   #1
Red87DropTop's Avatar
Red87DropTop is on a distinguished road
Guys, I did a search on this but came up with squat. My a/c blower fan quit working. I checked the fuse and I have no current going through it or to the back of the fan speed switch. I do however have current going to the a/c, heat, vent control. The compressor will come on and you can feel the a/c cooling but no fan. I have an 87 GT convertible, do these have a blower control relay and if so where is it located Thanks for any info. Jerry
Old August 4th, 2007, 04:19 PM   #2
1991 LX, 2003 SNK, 2007 S
11.3
cams-shelbycobra07 is on a distinguished road
Send a message via AIM to cams-shelbycobra07
could be your compressor
Old August 4th, 2007, 10:02 PM   #3
BlueOval's Avatar
BlueOval is on a distinguished road
Send a message via Yahoo to BlueOval
There is a blower motor resistor. If you drop the glove box down, you will see it to the left side going straight in. They are usually the culprit.
1990 LX Notch, with the heart of a 93 GT vert' (R.I.P.)
Old August 5th, 2007, 02:18 AM   #4
neverfastenough1's Avatar
If you have no current going thru your fuse, then is the fuse blown? Do you have current on either side of the fuse? The fuse for the blower and the fuse for the a/c gets power from the ignition switch. The fuse is before the resistor, so you should have power.
Threads Similar to: Blower Motor not working
AC not working chuck&monika 2005 - 2010 5 August 6th, 2007 01:33 PM
Exhaust set-up I am currently working on 2000Mustang V6 Mustangs 3 June 11th, 2007 01:42 AM
AC Not Working, Could It Be The Blower Resistor? Hate-a-Saurus V6 Mustangs 7 October 4th, 2006 06:18 PM
