fuel pump
Old August 4th, 2007, 07:54 PM   #1
skid6 is on a distinguished road
fuel pump
ok since im going from fuel injection to carb what do i need to do for fuel
and what kkind of pressure do i need does the fuel pump need to be on only when im trying to start it or does it need to be on as long as the car is running
Old August 4th, 2007, 08:03 PM   #2
TENGRAM is on a distinguished road
Re: fuel pump
i would use the simple pickup tubes that some companies sell (been awhile, i forget which companies) and a mechanical fuel pump...6-9psi. i used a carter on my 85 and it worked well without having to use a regulator.
89 GT t5 3.73
www.my5oh.com/
Old August 4th, 2007, 09:35 PM   #3
neverfastenough1's Avatar
You can go like Tengram said, or you can use the exisitng fuel pump with a regulator. You can also take the pump off and run a tube with a strainer to the bottom of the tank. Then get an electric inline fuel pump like the Holley blue one that is set for carb. People tend to go with the inline over the mechanical because the mechanical uses hp to operate.
Threads Similar to: fuel pump
fuel pump Baldy General Tech 2 October 3rd, 2007 10:45 AM
Fuel pump Mustang RacR94 V6 Mustangs 16 September 27th, 2007 06:36 PM
Fuel Pump? lugthug713 94-95 1 July 31st, 2007 11:38 AM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
