#21 |
Big timin' in a small town
Same thinng haped to me when I took of the intake on my speed density car and it was a vaccum line that was unhooked on the firewall guess i should have said what line.
#22 |
Its all good.
OK started her up after reconnecting the MAP and setting the TPS to .98VDC.... SHE RUNS GREAT! then after a few minutes, as Im setting the timing, it starts jumping all over the place (timing mark on the H.B.) abd now she wont idle. I went to check everything and could not get a voltage on the TPS, so Im replacing the TPS tonight (hopefully) and Ill post progress. I guess having the screw turned all the way in screwed up the TPS, it was the original 1988 component anyway...lol
#24 | |
Had to set the TPS alittle higher than .98 VDC to get the surging to go away, but not much. It idles at about 875-900 RPM and purrs like a kitten, no leaks (except the chitty azz Flowtech headers) I replaced the TPS and the plugs (extremely fouled) Im going to use the Ford Racing kit to relocate the PS pump to the former location of the A/C compressor. Then I got to finish up the interior and I can test drive it ![]() it shifts through all gears on the stands, and there is alittle bit of slack in the rear end, but I think its normal... I will need to upgrade the suspension ft and rear but itll do for now. THANKS TO EVERYONE WHO HELPED WITH THIS BY THE WAY! ![]() Ill see if I can get some pics, but it doesnt look much different...just runs now ![]() I got to swap the tires over to the good rims (turbine stock 88 GT wheels ) and then its all good.
#25 |
shit no man im only about 1.5 hours from you. Im on hwy 431 south of huntsville, go thru guntersville, then you hit albertiville, go to far and your in boaz.
1986 Mustang GT t-top time piece! |
#26 | |
It wont look like much but once I get it running I can start planning the mods. I think I have a good base to work from. Right now I am taking a break so I can help my brother move this weekend....ugh... Im putting in the carpet and seats and center console on friday night so I can test drive and Ill throw you a message when I think It can make a trip. ![]()
#28 |
OK...
All is running and exhaust is intsalled back to the FlowMaster 50s. Im leaking (more like seeping, and then running out of the bell housing when I park)from the rear engine oil seal, but everything else is going good. I installed a stock manual fan and shroud, because the dual 12" electrics werent cutting it. everything works except my headlights....I think I have a bad light switch, so im going to get a new one and try it out. I been deploying all over and I leave for Germany on Sunday. After I get back in October, I should be able to get the body finished up and MAACO is going to paint it for me (with a warranty). Ill try to get pics up before I leave, but time is tight right now and Im not even working on the car right now.... so please bear with the progress gaps. Ill start a new thread when I get back and post up some pics. |
Threads Similar to: Surging 5.0....Please help
| Compressor surging. Need new bypass.... | Stangtuner | General Tech | 12 | January 13th, 2008 05:40 AM |
| engine surging | chickenbot | 5.0 Mustangs | 13 | November 13th, 2007 01:31 AM |
| gt surging when in gear with brake on or ac on | dobermean | 99-04 | 1 | August 20th, 2007 10:18 PM |
| surging idle help | jam77 | 5.0 Mustangs | 7 | August 20th, 2007 06:45 PM |
| Engine Surging @ Idle | Milner62 | General Tech | 0 | August 22nd, 2006 02:56 PM |
