#21 |
i think ill buy my water pump from summit then....
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
#22 |
wow today it was so hot that it got to 200 while driving.....so i was thinking of getting the 2row summit aluminum radiator.....i have a 3 row in now but dont know how long its been there and you can see corrosion. also...will 8mm plug wires be better then 7mm? i have 7's on there now....and can i just upgrade the blaster coil? like this http://store.summitracing.com/partde...5&autoview=sku
#23 |
this is a local speed shop to me. 256-582-4112 Soutern Marine & Automotive.
He sales aluminum radiators cheaper than any ive seen. I bought one last year for like $150 All i had to buy was a cap and the overflow nipple for the neck.
1986 Mustang GT t-top time piece! |
#24 |
that place is farrrrrrrrr away like 4 hrs away......the summit store is like 1hr in
McDonough
#26 | |
#27 |
have you thought about using an electric water pump?
#28 |
so if i upgrade the coil all i do is plug it in and its good? i use the 50/50 mix ive never tried mixing my own....ya ive thought about using an electric water pump.....but there more then i want to spend.
#29 | |
#30 |
what about the mr.gasket t-stat? ive herd those are pretty good.....
#31 | |
#32 |
so would these help or just a waste of money? http://store.summitracing.com/partde...0&autoview=sku
#33 | |
#34 |
just changed my radiator to the Summit Aluminum one.....and so far its works alot better, its .25inches thicker and around the same length. i was dumping out my old radiator and it was nothing but rust
#35 |
I'm on the fence on the cheap aftermarket engine accessories.
Within a period of a few months at about my 130K mile point, my factory original alternator, water pump, starter and PS pump all crapped out and all were replaced with cheap local store replacements [1]. The replacement water pump failed within a few weeks. The seal went bad and although they gave me a second replacement at no cost, they suggested I replace the fan and the clutch as well. In fairness, it probably really was my fan as it was the original plastic one and it had many cracks in it and was starting to warp. The alternator died within hours. No idea of the cause but the second replacement has worked since. No problems with the starter and the PS pump. [1] A side story on this. Not only did the above fail within a few months but it was also my sway bar bushings, my engine mounts, my 2nd gear synchos, my radiator and my rear end cover gasket and seal. Other then that period of a few months at 130K miles where all that crap failed at once, I had no issues before that or after that.
#36 |
talk about a horrible time. as far as i know i have like 140k + on mine....but my fan as cracks but it still works fine, i replaced the fan clutch. there is a link above, from stangzilla, for a summit waterpump.
Threads Similar to: what do you guys think
| One last opinion from you guys 05+ guys... | 1FastFox | 2005 - 2010 | 29 | October 8th, 2007 05:55 PM |
| What do you guys think of the new avi? | Drick | The Clubhouse | 43 | September 30th, 2007 04:51 PM |
| Hey guys | Saleenwolf720 | New Members Introductions | 11 | March 28th, 2007 10:42 PM |
| what do you guys think about these? | B0B | 99-04 | 8 | January 12th, 2007 01:50 PM |
| New Guy And Need Mustang Guys Advice, Come Comment Guys! | redneckstone | New Members Introductions | 11 | October 4th, 2006 07:02 PM |
