LinkBack (1) | Thread Tools |
#1
1989 Mustang questions and issues
Hello all. I just picked up a mustang and have some questions/issues, this is my first mustang/ford. Here is a run down of the car.
Here is what I have noticed so far with the car. When it is warmed up and you get on it pulls fair. The guy says the timing is set low for the nitrous (12 degrees). I am sure it would pull a lot better with the timing upped. At idle it stinks of fuel, it is running pretty rich. On cold starts it doesn’t like to run. You have to feather the gas to get it going. If you try to take off it likes to pop and sputter. It seems if you get it up to 2,500ish there isn’t any issues. After it is warmed up it will surge sometimes if you are cruising at 1,800 to 1,900ish rpm. It feels like you are tapping the gas. The check engine light is on also. The guy said there isn’t a chip/piggyback on the car. He just turns the timing down and raises the fuel from 40psi to 44psi when running the nitrous. It has a stock looking FPR that when you pull the vacuum line off there is a adjustment screw. I was looking around and it looks like the TwEECer maybe ticket to having a nice driving car that I can switch when I am running the nitrous. Anyone have an opinions on how I should fix/mod the car? |
I forgot I have an 89 ford card for my OTC2000. I pulled the codes
31-PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts. 85- Canister Purge Solenoid circuit failure. 84- EGR Vacuum Solenoid circuit failure. Then I did an engine check thing and got 12- Cannot control RPM during ER Self-Test high RPM check. 21- ECT out of self test range 0.3 to 3.7 volts. 31-PFE or EVP circuit has intermittently failed below minimum voltage of 0.24 volts. 41-HEGO sensor circuit indicates system lean (right side). or No HEGO switching detected always lean (right side). 91- Shift solenoid 1 circuit failure (E4OD). or No HEGO switching detected always lean (left side). or HEGO sensor circuit indicates system lean (left side). I am sure what the terms are. HEGO mean the o2 right? Is the left side the passenger side? Is there anyway to get rid of the 84 and 85? What is the PFE or EVP stand for? THanks for the help! ![]() I have some injectors rated at 27lbs at 39psi. |
First, I don't recall 27 lb injectors. Second, Tengram will be on hopefully n a while. It will help him if you warm up the car first, then do the test over. Some of your codes indicate a cold engine test. The 91 and 41 are saying its running lean. The PFE and EVP are egr related. Hopefully they will go away along with the lean codes when done with a warm engine, but its not looking good for them. The one that gives the indication the most that the engine was cold is the ECT code. Re-dong it warm will answer some questions for him.
#4 | |
thanks |
95 opalfrost gt
From the pic it looks like those are stock 19#s.
I don't know if these will help but its the first ones that popped up.
http://www.adaptiveperformance.com/egr.html Also, according to FordFuelInjection the KOEO test has to be done above 50 degrees, and the KOER test has to be above 180 degrees. http://www.fordfuelinjection.com/?p=28
#7 | |
#8 | |
Moderator
There's a reason Ford codenamed them the Terminator
1990 LX hatch
If the KOER test gives the cant raise Idle code its 1 of 3 things vacuum leak, bad IAC, or bad MAF signal. The lean codes, and the part throttle studder lead me to think vacuum leak. Usually a vacuum leaks "symptoms" dissappear at heavy loads, depending on how bad they are.
#10 | |
I did replace the ECT sensor and noticed the coolant was really low. Like 3/4 of a gallon low. I topped it off and the drive to work seemed smoother but it was running hotter. It was within the "normal" on the gauge but was getting close to the red. What do these motors like to run at? I am planning to swap the driver's side o2 tonight (that is the "left" site, true?). thanks again for the help. |
1990 LX hatch
Old avacuum hoses are a good start to check for leaks. the 3/8 plenum to plenum that is under the plenum is one that allways seems to give up.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/30359-1989-mustang-questions-issues.html
| Hego Sensor Location 89 Mustang | This thread | Refback | October 1st, 2010 01:07 PM | |
Threads Similar to: 1989 Mustang questions and issues
| 1989 Ford Mustang LX 5.0 | nobletype | 5.0 Mustangs | 14 | January 26th, 2007 08:30 PM |
| 1989 Mustang LX Tranny Problems Please Help | Steves LX | 5.0 Mustangs | 2 | November 15th, 2006 03:44 PM |
