oil pump shaft and distributor
im working on a 302 conversion in a 93 coupe....i bought an aftermarket distributor that is the same as the duraspark 2 but i noticed that at the bottom where it slides over the oil pump drive shaft it is about 1/4" shorter than stock and im affraid that it will just twist off the top of the oil pump shaft....i even got a used distributor out of an old car and it was the same length....HELP
Threads Similar to: oil pump shaft and distributor
| drive shaft shop one piece steel shaft ok for automatic tran | mustang fanatic | 2005 - 2010 | 8 | September 24th, 2007 01:21 AM |
| Can oil pump shaft be swapped from the top?? | noyz25 | 5.0 Mustangs | 2 | July 28th, 2007 11:30 PM |
| New distributor? | GatoStang | All Other Vehicles | 1 | June 2nd, 2007 04:07 PM |
| Distributor ?? | jonnotch | 5.0 Mustangs | 7 | June 2nd, 2007 02:50 PM |
| Distributor? | jpretrack38 | 5.0 Mustangs | 3 | August 18th, 2006 11:02 PM |
