fuses......
hey ya'll, i just joined the site. anyway, i have a '86 Stang GT i just bought and the speedometer and gas gauge doesn't work. anyone know what # fuse the speedometer is? any help is much appreciated.
I'm pretty sure there is no fuse for te speedo, check you connection at the back , alot of time people break them while takeing them apart, also check the connection at the tranny. Gas gauge may just be a bad ground on the tank, does the gauge move at all??
Big timin' in a small town
Theres no fuse for the speedo because it is cable drivin most. Most likely the speedo gear is stripped out all or most of the teeth are missing. As for the gas gauge it is probly the float in the tank for the sending unit it either dosent float anymore and sank to the bottom are the sending unit it bad.
gas gauge is mostly likely a bad sending unit
85 svo. work in progress
thank u guys..........huge help............thanx again
Threads Similar to: fuses......
| Fuses | AJRight 2008 | V6 Mustangs | 1 | August 21st, 2007 01:44 AM |
| fuses? | thetrooper31 | V6 Mustangs | 7 | July 16th, 2007 07:36 PM |
| Fuses | sorrowfulkiller | 96-98 | 3 | June 14th, 2007 12:26 AM |
| fuses on 96 gt | shan | 96-98 | 3 | May 19th, 2007 08:31 PM |
| Pulling Fuses | Amanda | 99-04 | 8 | April 26th, 2007 10:43 PM |
