Spark plug wires - what do you use?
Old August 9th, 2007, 02:42 AM   #1
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
Just wanted to get some feedback from you guys about spark plug wires. I'm putting GT40Ps in right now and I think my wires will hold out for a while, but I noticed (as I took my engine apart) that one of the wires has already scorched through the insulation as it laid on a header.
So I'm trying to find some 90* boot options in a Jegs or Summit catalogue but they are few and far between. And sometimes quite expensive. I was thinking about ordering a universal / cut to fit thing and doing it myself. Has anyone ever done this, and if so, what all tools do you need? I know at least one kit said it included a stripper - should you need a particular crimper? What is HEI and what type socket do we need for the spark plugs?
Or does someone have a kit they are using with 90* spark plug boots? Any good recommendations? I think the consensus around here is the Ford Racing wires are crap, but other than that I don't know what's up.
Thanks in advance.
Old August 9th, 2007, 10:25 AM   #2
ScratchinFerTraction's Avatar
ScratchinFerTraction is on a distinguished road
I've heard great things about Taylor wires from Darrel so I went with these:
http://store.summitracing.com/partde...5&autoview=sku
Assembly on the first one is really a pain in the butt, I found some tricks after that one.
1. Connect to dist, determine length
2. Use razor blade to cut off, add the length you will strip to overall (ie add an inch)
3. Carefully cut off the insulation (silicon part) by rolling the blade around the wire one inch back
4. LOTS of lube on the outside end of the wire, lots of lube inside the boot back (keep the lube off your hands)
5. Push the wire into the boot while spinning
6. Fold back electrode and put on crimp connector
7. Use larger part of slip jaw pliers to "roll" crimp the connector on (making sure it is rotated how you want the boot on
8. Grap the connector where the plug will go in with needle nose pliers and pull the boot over
9. Install.
I found the 135 degree boots get the wires away from my shorties and on top the valve covers, no marks after 4 months, but I keep them off the headers with the cheap wire looms.
Old August 9th, 2007, 12:51 PM   #3
nitrouskid is on a distinguished road
i had a set of gt40p heads on my 87 and i had the sme problem i just bought a set of mac headers specially designed for the heads and then you can use any of the shelf plug wires
Old August 9th, 2007, 02:13 PM   #4
sivart is on a distinguished road
i got some of those duralast plug wires and they never move....there only 7mm but i havnt had any problems with them touching the headers
I just read an article about the dangers of drinking ...
And it scared the crap out of me.
So that's it...............
After today, NO MORE READING.
Old August 9th, 2007, 03:32 PM   #5
Yeah, but the headers I've seen cost more than what I paid for the heads.
Anyways, I think I have some JBA shorties from a previous owner, according to the product number. The clearance looks fine, but like I said, one of the wires was scorched through even before I put the GT40Ps on there. I think I should replace the wires anyway and I was looking for some 90* sets.
Thanks for the feedback so far guys.
Threads Similar to: Spark plug wires - what do you use?
plug wires whitemustang02 V6 Mustangs 20 September 22nd, 2007 01:21 AM
Spark plug wires and coils? shadow98gt Modular Mustangs 2 May 19th, 2007 12:24 AM
Spark plug wires SPF0percent V6 Mustangs 5 February 7th, 2007 12:16 PM
New Spark Plug Wires itschristorres8 V6 Mustangs 22 October 7th, 2006 03:25 AM
spark plug wires King Mustang V6 Mustangs 6 July 19th, 2006 05:45 PM
