Yeah I'm a newbie with a couple of quick questions
Old August 9th, 2007, 01:24 PM   #1
1989 Mustang LX
89StAngerLX is on a distinguished road
I have now owned my Mustang for about 7 or 8 months. As much as I like the car I must say I feel it was a mistake to buy one that someone else did all of the engine work on. I know its a 306 but have no idea as to what kind of internals I have. As for the work done on the engine the guy did a really good job.
Ever since I got the car the check engine light would come and go. I finally took the time to read the codes and I came up with the EGRVP, TPS, & MAP/BARO sensor codes. It seemed to still run pretty good up until the last couple days. I now have to start the car 3 times and on the third time keep giving it gas to keep it running. I've been thinking that I need to check the fuel filter and replace it. I was wondering if there was anything any of you could think of.
I have also noticed that the fuel injectors have been replaced but haven't been able to find out what size they are with the numbers I've found on the sides of them. I did notice they have a green top on them though. Any thoughts on what size they are? Thanks for the help.
Jesse
Old August 9th, 2007, 01:41 PM   #2
5mustang0 is on a distinguished road
you didn't meantion if u took care of the codes that came up or not if u didn't that prolly could cause that to happen
Old August 9th, 2007, 01:46 PM   #3
1989 Mustang LX
No I haven't taken care of the codes yet. At the moment I'm a little tight on cash. I've been trying to figure out which, if any, of the sensors would cause it to act like that. I intend to replace them all I was just trying to fix the hesitation before it messed something else up.
Jesse
Old August 9th, 2007, 01:55 PM   #4
yea thats were i would start is those codes i'm not sure what those codes mean though
Old August 9th, 2007, 01:55 PM   #5
notsoslow50 is on a distinguished road
Send a message via AIM to notsoslow50
i usually always go carbed i dont like sensors and everything at has to do with fuel injection. thats my 2 cents..lol..im pretty sure you can go to jegs or summit racing and search your brand and pretty much narrow it down to what size injectors you have. i would go to summit it might be a tad bit easier to narrow down. you can always throw some injector cleaner in and see what that does it might have some carbon buidl up.thats always a possibliltiy im not good with fuel injection though..always start from the bottom up, get some injector cleaner see what that does, change the filter, check fuel pump then start going serious..lol
Old August 9th, 2007, 01:59 PM   #6
TurboLX's Avatar
1988 Mustang LX Turbo
well since its a 306, its a stock block bored .30" over
and a simple fix to the car is to remove the check engine bulb, since the car is modded and will be modded more, the check engine light will never go away...
so it's best to remove it so it doesnt melt the instrument bezel sfrom it being on constant, but it is always a good idea to scan the car evey couple of months just to make sure everything is an ok order
Old August 9th, 2007, 02:03 PM   #7
1989 Mustang LX
Well the light goes off for a while and will come back on. It doesn't stay on constantly.
Here are the codes that I pulled:
22 MAP (vacuum) or BARO signal out of range - MAP
31 EVP - EVP signal is/was out of range - EVP
EVR - EVP signal is/was low - EVR
PFE - PFE signal is/was low - PFE
63 Throttle Position Sensor (TPS) signal too low TPS
Jesse
Old August 9th, 2007, 02:11 PM   #8
yeaa def do what turbolx said..thats the best bet..or go carbed..lol
Old August 9th, 2007, 03:33 PM   #9
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
The only code i have on mine is the same egrvp dosent isnt it have something to do with the exhaust valve sensor or something like that will it make any problems with the motor
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old August 9th, 2007, 03:50 PM   #10
1989 Mustang LX
That is the EGR valve position sensor. I was wondering if any of these would make my car hesitate all of the sudden. I've been driving the car with these codes for about a month and a half now. Its been fine up until the last couple of days. It acts like its not getting enough gas and is trying to die on me. After driving for a while though it seems to clear up.
Jesse
Old August 10th, 2007, 02:34 AM   #11
Stangzilla's Avatar
Stangzilla is on a distinguished road
If I am not mistaken the plug for that is right next to the TPS plug? I have no EGR system on my car and it was just an open plug. That will cause the light to come on. They make a jumper that you can plug into it to satisfy the circuit. Thats one code down...Hopefully..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old August 10th, 2007, 09:04 AM   #12
1989 Mustang LX
When I first start the car it really just doesn't want to idle or anything. If I take off it starts jerking really bad and tries to die. It also sounds like it may be backfiring but if it is, its doing it at the engine. I can feel what almost seems like a pop through the floor board.
Jesse
Old August 10th, 2007, 04:41 PM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
that usually means it's running reallt lean.
Old August 11th, 2007, 10:03 AM   #14
baine21225's Avatar
sounds like you have your hands full, good luck
Threads Similar to: Yeah I'm a newbie with a couple of quick questions
Just A Couple Questions Youngin The Clubhouse 44 November 13th, 2007 02:11 AM
help with a couple of questions sixpack 5.0 Mustangs 3 October 1st, 2007 08:38 PM
Few quick newbie questions mutabi 99-04 20 September 7th, 2007 08:06 PM
New Car!!!! So Couple Questions Speedstang302 5.0 Mustangs 4 April 23rd, 2007 03:16 PM
a couple questions trueballerisme 2005 - 2010 7 December 10th, 2006 03:39 AM
