does this setup sound good for about 18lbs of turbo boost?
Old July 13th, 2006, 03:41 PM   #1
frankenstein is on a distinguished road
ive got 32lb injectors, 75mm throttle body and spacer, 76mm mass air, high flow fuel rails, ported (75mm) cobra upper and lower, and soon to have my gt40 cast heads ported and B cam? do i need to go with bigger throttle body/injectors/maf?
Old July 13th, 2006, 04:39 PM   #2
mdvaldosta's Avatar
11.47@120.58
Your injectors are gonna get maxed out pretty quick, you'll need at least 42#'ers.... 18# of turbo boost is pretty serious, 500hp will be pretty easy and that's where blocks start to break. I wouldn't use a B cam with a turbo, you'll be bleeding off alot of boost. Find something with a staggered intake / exhaust duration... something designed specifically for boosted 5.0's.
Old July 17th, 2006, 12:29 AM   #3
mikes93fox is on a distinguished road
I would like to add the most bang for your buck cam that FRPP makes for boost is the F cam. And I would take MD's advice on the 42's with that much boost. You didn't list your fuel pump in your mods, you definitely need to upgrade to a 255 lph and possibly a boost a pump or t-rex unit to help with the fuel pressure. I would really watch how much you try to get away with on that block, 500 is almost always the universal maximum and then it's just a ticking time bomb. Your probably going to be happier with lower boost numbers for maximum horse and longetivity out of your setup. I'm thinking somewhere around 12-14 psi.
93 vert - stock bottom end, AFR 165's, Crane 1.7 RR, F-cam, Ported Cobra upper and lower, BBK 65 mm TB, Pro-M 76mm MAF, FRPP 24lbs inj, Novi 1000, BulletProof AOD, Alum. rad, MSD 6a, Blaster 2 coil, FRPP 9mm wires, Holley 255 FP, 3:73, and Cobra R's
Threads Similar to: does this setup sound good for about 18lbs of turbo boost?
Best Exhaust Setup (Sound, Power, Cost) Kemp"Da_Chit"08GT 2005 - 2010 25 November 17th, 2007 11:22 PM
Hows this setup sound Drick 5.0 Mustangs 11 May 21st, 2007 09:22 PM
Whats a good turbo setup for my 2004 mach 1? Saleenwolf720 99-04 11 March 28th, 2007 02:16 AM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 10:56 AM
Hows The Setup Sound... RC02GT 99-04 6 September 12th, 2006 05:51 PM
