Discussing Will 4.10's mess up speedo? in the 5.0 Mustangs Forum. Hello. I have a 88 5.0 notch that I bought not too long ago. ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Hello. I have a 88 5.0 notch that I bought not too long ago. It was a swap car so i put the 5.0 speedometer in it. I also had the speedometer gears replaced. It still seems not to read the correct speeds and is like 10 to 20 mph off. I was wondering if it is possible that the previous owner put new motive gears which caused the speedometer to be offset. It is just a theory because he put a lot of work in the car so why not put gears. It also kicks slightly when shifting at low rpm, and my mechanic told me the engine and trans are practically new. What could solve my speedo issue? thanks
![]() 1988 LX auto- Pypes violator cat-back, UPR X-Pipe, Shift Kit, 4.10 Gears, Pulleys, Suspension upgraded, CAI 1999 GT 5spd- CAI, Pypes violator cat-back |
1987 ford mustang gt
well see when shes done
They will if you do not have the right gear for the speedo,and tire size can through your mph off a little bit.And is it a 5 speed or an aod.Do you know what year the engine and trans is?
Moderator
yeah mines whack. says 110 when im doing like 70
2004 SVT Cobra 2000 LS1 Camaro
#4 | |
Rotating The Earth 1320 Feet At A Time!! The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” |
1989 Mustang GT
I put a 23 tooth speedometer gear in my aod and it was also an easy swap. I have 4:10's in the rear. Just take out the bolt for the speed sensor and pull it out of the transmission. I had to replace my cable too (twice actually) b/c the headers kept melting them. I got it re-routed and seems ok now. My speedometer used to jump around and all that but now it is smooth.
He is no fool who gives what he cannot keep to gain what he cannot lose." Jim Elliot ![]() Garage: http://www.moddedmustangs.com/forums...-member-10915/ |
Moderator
yeah ive just never gotten around to doing the gear thing in the trans. i do have a 5 speed. but i dont drive my car that much, and when i do its not like i go the speed limit so it doesnt bother me
Threads Similar to: Will 4.10's mess up speedo?
| How can I change my speedo for 4.10's? | militant54 | 96-98 | 20 | October 17th, 2007 05:22 PM |
| speedo | bigdaddy09 | 5.0 Mustangs | 10 | September 19th, 2007 02:00 AM |
| List of cars not to mess with??? | 04GTAMPA | Street | 45 | April 18th, 2007 10:58 PM |
| will i have to mess with my h pipe and exhaust if... | YNOT | 5.0 Mustangs | 6 | March 25th, 2007 03:09 AM |
| a little mess | insnedrmr | 5.0 Mustangs | 1 | February 18th, 2007 07:55 PM |
